Originally Posted by Dave Terpening
Ha! I wonder what happened to the windows on that Cadet? Your Cadet looks amazing. What a great job!
Well Dave, I had to remove the
windows because the
fiberglass needed a lot of work because of all the cracks in the window openings ! While I had them in storage I dropped the back window on the ciment floor on the right hand corner and snapped off 4 small pieces and got a crack also!!!!!(the dreaded cadet curse) So I glued the pieces back on the window using 2 part epoxie, then I
light sanded the corner, masked the raised part of the window, then sprayed bed liner around the edges on both sides and the primed and painted to fleet white . I did that to give the edge more strength and to hide the repair(try to trick the eye!) Then,to protect both windows even more, I picked up at canadian tire some moulding(the stuff you put on the edge of car doors not to ding the other car next to you) A little costly maybe... but considering how rare these windows are ,well worth the investment.
