...that 'S' word & lawn art - Page 3 - Fiberglass RV
Old 01-14-2009, 09:04 PM   #29
james kent's Avatar
Trailer: Boler 1984
Ummm.
Hate to have to tell you this Jim, but you had better check you basement for water coming up from under the floor. Never had a problem until today ...
I'm in the middle of cutting a hole in the concrete floor to set a sump pump into. Can't figure out where the water is coming from. We are in the middle of the artic cold snap so it should not be surface water. Our city water pressure is down. Tested the water for chlorine and it came up negative and different from that coming out of the tap. That leads me to believe it is ground water.
So far we've sucked out about 20 shop vacs full of water and the new hole fills up almost as fast as we empty it. Stopped at home depot to get everything we need and the guy giving me all the parts forgot to mention that we also need a back check valve that was not included with the sump pump. Carol Ann is making another trip down to HD to get one as I write this.
I'm dirty, wet, tired and frustrated. Any idea's?
Oh man, Roy I really feel your pain. We've had so many coincidental things happen that I actually went and double checked every corner of every room in the lower basement with a high powered light. Knock on wood. We had a sewer back up last summer but Mr Roter Router fixed that and one of these days I'll have to remove the big maple tree from the front lawn. If your's is not sewer or city water Then I'm afraid I can't help much, and what a crappy time of year for it to happen.
There isn't an old well on the property by chance is there? I would really suspect a burst pipe somewheres. How about the cities fire hydrant system? Is it separate from the drinking water?
Carol Anne
I'm really sorry that I even brought up the subject of plumbing. Yes, you can say that you told me so.......
Jim
Old 01-15-2009, 12:44 AM   #30
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
I was thinking more like this one, Roy.
Way it's going up north this year ya'll need either
This Unimog (Mercedes Utility Truck) Snow Cutter
or
This Unimog
Both are instant killers of any size ! Even this one
Coach George Jessup is offline   Reply With Quote
Old 01-15-2009, 01:13 AM   #31
Roy in TO's Avatar
I'm not sure how the city is plumbed but I do know that they don't for sure. Documents went missing back in the 60's when the first merger of small towns into bigger cities happened. I'm not sure about an old well, possible but not for this house. I do know that there are underground rivers that the developers ran into digging for the new apartments at both the front and rear of our house. Another apartment flanks one side.
We never had a problem with the record breaking amounts of rain last year. At -20*C there is no runoff I considered the possibility of a water main starting to go, but there is a difference in chlorine levels and pH. I wonder if the ground is altering the water composition.
Stranger yet is that at about 10:00 PM as I was setting the sump pump into place the amount of water coming in dropped dramatically.
Old 01-15-2009, 08:08 AM   #32
james kent's Avatar
Trailer: Boler 1984
At about the same time that industrial usage drops off???
Old 01-15-2009, 09:00 AM   #33
Roy in TO's Avatar
What are you thinking?
Old 01-15-2009, 11:17 AM   #34
james kent's Avatar
Trailer: Boler 1984
A frozen pipe to a factory somewhere in the area maybe???
Old 01-15-2009, 02:43 PM   #35
Roy in TO's Avatar
Water is bubbling up from the end of the driveway.
Spent 5 min on hold waiting to report it on the emergency water line.
Will keep you posted.
Old 01-15-2009, 03:38 PM   #36
james kent's Avatar
Trailer: Boler 1984
HEY GUYS!
STREET HOCKEY!
Old 01-15-2009, 03:50 PM   #37
Roger C H's Avatar
Unhappy
Some people in Washington have water in their basements also:
Old 01-15-2009, 04:55 PM   #38
Roger C H's Avatar
Talking
Anyone for a snow doughnut?
me!, me!
http://www.wsdot.wa.gov/traffic/passes/nor...07/pictures.htm
Enjoy
Old 01-15-2009, 04:55 PM   #39
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Can't remember a stretch of 9 that has those dividers on it, where was this, more exactly??
Old 01-15-2009, 06:39 PM   #40
Roy in TO's Avatar
Love the snow doughnuts! And the Bimford Blower
Updating water story. Took the city 1.5 hours to get someone out. They spent an hour trying to turn the water off before giving up. Looks like it is going to run all night till a crew can make it out in the AM to dig down to the problem.
Other than the flowing stream in the center the rest of the driveway is shear ice. The water flows down to the garage, into a catch basin and then under the garage to empty into the yard a floor below. I'm crossing my fingers the pipe does not freeze because the next path of least resistance is into my garage. That is packed to the rafters with everything that I've been buying over time to do a planned reno for my business.
Looks like another sleep deprived night is on it's way.
Old 01-15-2009, 08:25 PM   #41
james kent's Avatar
Trailer: Boler 1984
All that snow makes me wonder how Gerry is making out this year in Maine?
Roy, Sounds like you're finally headed in the right direction.
Hey! where would we be without a little excitement, EH?
Old 01-15-2009, 09:16 PM   #42
Doug Mager's Avatar
YABBUT, who NEEDS that kind of excitement at this time of the year and under those conditions? Are any/some of your neighbours experiencing this same issue Roy??
Leaves vrs Lawn Tractor= FIRE! Pat B Ohio General Chat 3 11-13-2009 03:17 AM
Word for the day Roy in TO Jokes, Stories & Tall Tales 18 03-25-2009 06:32 AM
Nonfuncnional Organic lawn mower Kurt in BC Jokes, Stories & Tall Tales 1 12-08-2008 07:57 AM
WORD OF THE DAY Doug Mager General Chat 13 09-10-2007 09:52 PM
