Double-hulled unit (burro, uhaul, or?) 13-17' - Fiberglass RV
Old 05-26-2006, 10:27 AM   #1
Leslie L.'s Avatar
Trailer: 1984 Burro 13 ft and 2000 Burro 17 ft
Due to allergies and multiple chemical sensitivities, I've determined that I need a double-hulled make (easy to clean, doesn't hold odors), preferably with a fiberglass floor (plywood encased in fiberglass would be okay, might be able to deal with plain plywood if I put foil over it and then tile or hardwood).
I live in Bend, Oregon. Something in the Pacific Northwest, California, or Southwest would be easiest for me to check out and get home, though I'm open to other possibilities.
Also, since I'll be towing it with a white Toyota Previa (which looks like a white jelly bean or an egg, itself), it'd be great fun if the trailer I end up finding is one of the "eggier" models, like a little burro.
Thanks!
Leslie L. is offline   Reply With Quote
Old 06-04-2006, 12:26 PM   #2
Mike Watters's Avatar
Trailer: Amerigo & Trailmanor (popupish)
Indiana
You might also want to consider the earlier Scamps or Bolers with Ensolite on the walls. It's really easy to scrub down when neccessary.
For sealing the floor - all in all, other than foil - once you're down to the raw floor - it might be just as easy and more effective to mix up some fiberglass resin and spread it out over the plywood. I'd think you'd have a much more effective seal that way.
Would you be planning on replacing the wooden doors as well? One or two members have used plastic cutting-board material as a replacement. Might be a good idea given your requirements.
Mike
Mike Watters is offline   Reply With Quote
Old 06-04-2006, 04:07 PM   #3
Carol A.'s Avatar
Trailer: 2012 19' Escape
Check the referrals - there's an American Adventure (looks like a Burro or UHaul) in Puyallup, WA
Carol A. is offline   Reply With Quote
Old 06-05-2006, 05:07 PM   #4
lwehrly's Avatar
Trailer: Honey
Leslie...
Check out the Trails West Campster in the for sale forum. It has not insulation on the walls. Just fiberglass. It looks like a very clean unit. It might be what you want, and the price is really attractive! And its not too far from you.
lwehrly is offline   Reply With Quote
Old 06-05-2006, 09:32 PM   #5
Leslie L.'s Avatar
Hi, All--
Thanks for the helpful information!
I just took delivery this morning of a 2000 widebody Burro that I bought Saturday, sight-unseen (and smell unsmelled) from an ad in RVTrader online, down in San Diego.
So far, I am actually having a bad reaction to it (see original post), but am very hopeful that once I'm through removing carpet, cushions, toilet chemicals, etc. it will be just the thing. If not, I'll be looking into those leads you've sent in the last couple of days !
N.b.--I came across the "American Adventure" several days ago, before locating this Burro, and called the number. Waited on tenterhooks...no reply.
I'll keep everyone posted as to whether the one I found works out , or whether I'm still "Eggless in Oregon."
Thanks again,
Leslie
burro, u-haul, uhaul
Burro Widebody, Burro and UHaul Nancy Reeves Problem Solving | Owners Helping Owners 15 06-27-2011 08:41 PM
Burro? uhaul? other? Judith Kennedy General Chat 5 09-15-2009 02:28 PM
Want Casita, Scamp, Burro, Uhaul, etc James D. Wanted: Molded Fiberglass Travel Trailers 0 02-21-2009 03:33 PM
Double-Hulled - Which Brands/Models Mitchell General Chat 5 09-12-2008 10:14 PM
Mounting an Awning on a Burro (double shell) S Sato Modifications, Alterations and Updates 17 03-05-2006 07:16 PM
