Socal: looking for a light travel trailer - Page 5 - Fiberglass RV
Old 05-26-2015, 05:39 PM   #57
Trailer: sprinter looking to tow something
That cab over in the esprit is great! Just looked it up.
I was thinking one of the 21 or 22 ft shortie travco's with a well tuned motor might not be so bad on gas. I'm not sure how not-bad, but a 318 in that has to be a fair deal better than my 460 with barn door aero.
I wouldn't really mind the "experienced" exterior look to a 60's or 70's travco. I would be concerned about the interior and functional bits on something that old. It would have to be something already gone thru. I don't think I know how serious I would be about one until I find one and look at it. They are really really old.
Comp is offline   Reply With Quote
Old 05-26-2015, 06:41 PM   #58
TRAVCO vs. Argosy
[QUOTE=Comp;525027]That cab over in the esprit is great! Just looked it up.
Similar to the shorty TRAVCO, which are considered "Rare & Collectable" in that group, is the Argosy shorty motorhome/bus. Airstream made tons of these, both as RV, but most as busses for local transit companies. As a result, they can almost be called "Plentiful" at least as compared to TRAVCO shorty's.
Old 05-26-2015, 07:56 PM   #59
Originally Posted by Comp View Post
Its a fifth converted to tow off of a raised bumper hitch. Makes me very uncomfortable looking at it.
Agree with Jon its not been converted &/or messed with that is the standard Scamp hitch set up for their 19'.
Old 05-27-2015, 06:49 AM   #60
From the pics I saw (removed from the ad now) he did have a big pickup. I dont get the reasoning behind it...
Likely was the one I saw, then.
I can think of two reasons someone might try to do what he did. One is that he wanted to carry something else in the bed (quad, maybe). That would make a bad situation far worse. Second is that the bed rail height on a lot of newer full-size pickups (as well as older ones with raised off-road suspensions) requires an optional raised suspension on the Scamp. The truck may have been too tall to fit under the Scamp's loft.
Or maybe it's just a flip.
Old 05-27-2015, 10:15 AM   #61
Good point, IIRC the advertiser did have a lifted late model 'agressively' styled truck with the raised sides to the body and bed.
Thank you, I will put argosy on my radar. Had no idea those existed. I also see some argosy trailers but I think they are aluminum.
Old 05-27-2015, 11:26 AM   #62
One of my girlfriends found and restored an Argosy. She turned it into a real nice trailer but she was fortunate to have a husband who was a vintage car guy, who was very good at taking things apart and putting it back together & paying attention to detail! The Argosy was built by Airstream, using painted aluminum but were not made up with as many different panels and rivets as the Airstream.
Lots of info on the Argosy at Tin Can Tourists - Argosy.
Old 05-27-2015, 11:34 AM   #63
The Argosy also differed in that it had formed steel (?) front and rear end caps, apparently to allow for a wrap around window.
I'd never heard that they were built with fewer rivets, or any thing else suggesting a lower quality of build than the parent Airstreams. I think that the first ones appeared in about 1977-78
Old 05-27-2015, 03:59 PM   #64
They use fewer rivets on the outside body simple due to their being made with fewer outside panels than the traditional Airstream.
Old 05-28-2015, 03:05 PM   #65
The used RV Sprinter prices are astounding. $40k-$60k used? When you can get a used cargo version for $15k. Makes towing with a cargo look like a absolute bargain. With a small to medium trailer I would bet you could out MPG the C and even B class Sprinters too. I've got to keep mpg in mind to fend off the temptation of some of these other options..
Old 05-28-2015, 03:22 PM   #66
sokhapkin's Avatar
SW Florida
No wonder. Installation of RV equipment and interior in a van takes time and money. Look at Sportsmobile Custom Camper Vans - Your Home Away From Home
Sergey
www.callwithus.com
Old 05-28-2015, 03:54 PM   #67
Borrego Dave's Avatar
Trailer: Casita SD17 2006
MPG, mmmmmm. I was tickled when I went from 6 to the mid 7s when I changed from one large RV to a newer bigger one. I'm sure I'm on the other end of the list for having/using an RV and worrying about MPG. Yes, it is nice to get higher mileage but it's just not very high on my list. YMMV
Old 05-28-2015, 03:57 PM   #68
rbryan's Avatar
YMMV - Your mileage may vary. No pun intended?
You're right. Priorities differ greatly from one person to another. MPG is a big concern for us, but not for some others.
rbryan is online now   Reply With Quote
Old 05-28-2015, 05:30 PM   #69
Yea but the thing that doesn't make sense to me, you can get a really nice e350 class C for 20 to 30k. Same size, year, the gassers are half what a sprinter runs! You can't tell me it costs twice as much for the same labor and materials just cause its a sprinter that is being converted rather than an e350.
Old 05-28-2015, 05:34 PM   #70
[QUOTE=rbryan;525463]YMMV - Your mileage may vary. No pun intended? QUOTE]
Not really but it does work
light
Wanted light weight travel trailer jimdee1269 Wanted: Molded Fiberglass Travel Trailers 5 07-25-2014 09:57 AM
Trailer wanted in SoCal, under 1500 lbs juliep1114 Wanted: Molded Fiberglass Travel Trailers 9 06-13-2014 01:24 PM
1984 Tear trop super light travel trailer - $1750 (Cle Eelum, WA) hamstercampster Referrals: Molded Fiberglass Trailers 0 07-29-2011 10:13 AM
FOUND - Wanted 13 Uhaul/Burro SoCal caleb Classified Archives 10 05-18-2009 12:14 AM
OT: Socal teardrop article Ken C General Chat 1 03-27-2009 04:32 PM
