Wanted Double axle fifth wheel - Fiberglass RV
Old 02-23-2016, 01:06 PM   #1
Bigfoot or other. I've got a single axle now and its a bit bouncy.
Thanks
griph0n is offline   Reply With Quote
Old 02-23-2016, 01:38 PM   #2
Escape 5.0 TA
Old 02-24-2016, 09:35 AM   #3
vintageracer's Avatar
Trailer: Uhaul
Thanks
Do you currently have a "Torsion" axle or "Buggy" spring axle under your current trailer?
vintageracer is offline   Reply With Quote
Old 02-24-2016, 01:09 PM   #4
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
My Scamp 5th felt very bouncy the first day I towed it home (a long trip). Then I found out the tires should have been at 45 psi (cold), not 30 psi which was my first, uneducated, guess. At 45 psi it is well behaved. I was even researching those fancy, expensive flex mounted hitches at that time. Not needed, it turned out.
Old 02-24-2016, 01:11 PM   #5
Bouncy can be caused by a number of things from improper loading to worn out axle. If just those two things transfer to a double-axle, not much is going to change. It's still going to bounce.
Old 02-24-2016, 02:03 PM   #6
Marty Smiltneek's Avatar
Trailer: 1972 Boler American
Wisconsin
double axle fift wheel
Seems to me there was a project by someone on this or bolerama that did this conversion to a scamp. I think it was at least 7 or 8 years ago. I don't remember anything anymore.
Marty
Marty Smiltneek is offline   Reply With Quote
Old 02-24-2016, 02:38 PM   #7
Marty
It was Merle Lilly. I helped him with the write-up on how he did it. It's in the Document Center. Fiberglass RV - Document Center - TandemAxleSetup
Old 02-24-2016, 03:11 PM   #8
Wisconsin
Donna, you are the best! I would love to convert a 5th wheel to tandem and add a toy hauler hatch to the back to haul my bikes around on long trips.
Old 02-24-2016, 03:49 PM   #9
Trailer: Bigfoot B-17 CB
There should be a shock absorber kit available to add shocks to any trailer with leaf springs. That would reduce the bounce and if that is the only reason you are thinking about getting a new trailer, it would be a much simpler solution.
Jack L is online now   Reply With Quote
axle
OR | For Sale: Rare 1987 Bigfoot Fifth Wheel, 19' single axle levi For Sale: Molded Fiberglass Travel Trailers 12 04-19-2015 06:37 AM
Double Axle or Not Nordst Hi, I am.... 14 08-30-2012 10:55 AM
1994 20' Bigfoot Fifth Wheel Dual Axle Dick Smith Classified Archives 4 03-15-2010 08:38 PM
Scamp Fifth Wheel Wanted Erik Gripp Wanted: Molded Fiberglass Travel Trailers 7 01-16-2006 11:35 AM
