Wanted light weight travel trailer - Fiberglass RV
Old 07-25-2014, 07:29 AM   #1
Trailer: In the market
I am looking for a trailer I can tow with my Ford Ranger.. it only has a 3.08 gear ratio so it can only tow 1600 lbs. I would like to get one closer to 1200 lbs or under so I am not to limited on what I can put in it. I live in middle Tennessee and would like to find one within no more than a 3 or 4 hour drive so northern AL, southern, KY, etc... Would like one with a bathroom but that is not a deal killer... also air would be great... I'm on a tight budget so nothing too expensive. It is for 2 non-smoking adults.. Thanks for any help you can give me.
jimdee1269 is offline   Reply With Quote
Old 07-25-2014, 07:40 AM   #2
MC1
MC1's Avatar
Even if you find a trailer in the 1,600lb range and the 3:08 gears are pulling down the towing performance I would consider swapping out the Ranger rear end for something more useful. I see them advertised for around $300.
Old 07-25-2014, 08:14 AM   #3
You are asking a lot!
Be aware that manufacturers and sellers often underestimate how much these trailers weigh when loaded for travel. I see claims of "only weighs 900# and you can pull it with anything." For some real-life, loaded-for-travel data, check out the thread Trailer Weights in the Real World. Somewhere toward the end (post #237??) there is a downloadable spreadsheet organized in a way that makes it easier to compare different makes and models.
Don't know that there's a lot out there that will meet all of your requirements (bath, air) and come in under 1600#, never mind 1200#. One of the pop-top types (Hunter, Campster) might come closest.
Old 07-25-2014, 09:15 AM   #4
Thanks but a popup will not work for me... we just sold ours because I have a bad back and setting it up was a real issue. Thanks for the info on the weight issue. Someone else recommended we put a different sized rear end in for more towing capability so I may look into that.
Old 07-25-2014, 09:48 AM   #5
Just to clarify… the kind of pop-top I am talking about is not a tent trailer. Here's an example:
1973 Hunter Compact II - $3450
Depending on how they are equipped, they can be among the lightest of the fiberglass trailers. They also have less frontal area, which improves towing performance at highway speeds, and they fit into a standard garage. I have no idea how much effort is required to raise the roof, or if this would even interest you.
If you do look into increasing your tow capacity, it may involve more than just a rear-end swap. Suspension, brakes, cooling capacity, alternator size are among the other factors that have to be considered. I owned a basic 4 cyl/stick shift Ford Ranger at one time and they're, well… pretty basic.
Old 07-25-2014, 09:57 AM   #6
Thanks for the link... I will look in to that.. We had looked at a "pop-top" Northwind by Viking but it weighed 2400 pounds..not fiberglass... I will look at the Hunter Compacts... I think they would work great.
light, weight
Wanted: 13 foot Scamp, Casita, or other light weight camper brwall Wanted: Molded Fiberglass Travel Trailers 1 07-01-2014 09:39 AM
help - I am interested in buying a small, light weight trailer- total weight 2000 pdd pwedd Hi, I am.... 19 07-23-2011 12:50 AM
Looking in WA State light weight trailer Karen Lee F Wanted: Molded Fiberglass Travel Trailers 10 07-07-2010 08:57 AM
Looking for Used Lite Weight Travel Trailer Less than 2000 lbs MarciaK Wanted: Molded Fiberglass Travel Trailers 16 04-09-2009 05:30 AM
» Trailer Showcase
burro
Jody
Get Kamp'n
kgingeri
