Wanted: '78 Trillium 4500 replacement water tank - Fiberglass RV
Old 07-24-2012, 03:53 PM   #1
Trailer: 1978 Trillium 4500
Question '78 Trillium 4500 replacement water tank
Google's letting me down in my search for a new water tank.
The PO of my '78 Trillium 4500 put a large (4x6) rectangular hole in the water tank in order to.... Who knows? Sure beats me. Maybe he figured he'd make a nice hole to scrub the inside clean and forgot that the water would come out the hole?
There was a very badly attempted, leaky repair which I have removed. The repair was some sort of plastic sheet screwed on, over the hole and then "sealed" with silicone. The repair probably leaked worse than the hole.
Anyway, I'm 99% sure the tank material is the dreaded LDPE, which seems not to be (according to my research) patchable.
Does anybody have ideas for a source for a new tank? It's kind of an odd shape, but not terribly. It's essentially a long flat box shape, but it tapers from 6 inches high at the front to 4 inches high at the rear. My calculations put it at 13 gallons. It goes under the floor, beneath the dinette table.
spotcatbug is offline   Reply With Quote
Old 07-24-2012, 05:54 PM   #2
Roy in TO's Avatar
If it is LDPE, it is "weldable". See if there are any plastic tank fabricators in your area.
Old 07-25-2012, 10:12 AM   #3
Raz
Raz's Avatar
Vermont
How about enlarging the hole and installing a deck plate? Raz
Old 07-25-2012, 11:58 AM   #4
That is an awesome suggestion! I hadn't considered that, but, now that I think about it... Nerts! The hole is too close to the edge. Actually, I believe (I'm not looking at it right now) the hole includes the edge and maybe even a little bit of the adjoining side (this is where an attached picture would be sweet ).
I'm pretty sure I really need to find a replacement tank. I'm starting to think I'll need to get a different (available) tank and locate it somewhere else, like under one of the benches. I hate to lose the storage and waste the space where the old tank was, though.
Old 07-25-2012, 12:01 PM   #5
I'm not having any luck finding tank fabricators around Meadville, PA. Are there some other search terms I should be trying?
Old 07-25-2012, 12:29 PM   #6
Roy in TO's Avatar
Check local marina's (you are not far from Lake Erie) RV places and places that supply those agricultural tanks, I see a lot of them out your way. Somebody has to know who welds plastic in the area. I googled plastics from google maps of Meadville and found a lot of places. Seek and Ye shall find.
Old 07-25-2012, 04:32 PM   #7
Raz
Raz's Avatar
Vermont
The tank in our 2010 Trillium was made by Inca Plastics. It sounds like the same shape and since our 1300 was made from the same molds as the original, it most likely is. Was the water tank the same in the 4500? Nothing useful on the web site but contact info. Good luck, Raz
Tanks
Old 07-26-2012, 06:09 AM   #8
Tanks
Wow, thanks for the link. I'm emailing them now.
Old 07-26-2012, 07:31 AM   #9
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
This site has many different types and sizes of fresh water tanks.
RV Lights Lighting porch ceiling roof items in Class A Customs classacustoms custom store on eBay!
Might have something you could make work.
Good Luck in your hunting!
Spanke
Trilliums Rock!
trillium
Trillium 4500 replacement converter? spotcatbug Modifications, Alterations and Updates 68 07-23-2013 10:58 AM
Trillium 4500 Rear Window Large Pane Replacement spotcatbug Problem Solving | Owners Helping Owners 2 12-02-2011 02:19 PM
Trillium 4500: Need replacement door lock/latch Laurie Problem Solving | Owners Helping Owners 13 06-29-2011 07:19 PM
Propane tank / Battery mount Trillium 4500 1978 Gumpit Modifications, Alterations and Updates 14 11-20-2010 09:15 AM
Trillium water tank drain John Perry Problem Solving | Owners Helping Owners 5 10-15-2007 08:59 PM
