Amerigo - Fiberglass RV
Old 06-22-2014, 07:13 AM   #1
Trailer: Currently Shopping"
Alabama
Amerigo
Am looking for an outside panel that covers the fridge coils etc. The trailer is an Amerigo f16 1972 or3 model. Does anyone have one out there? phone 205681///4///7///4///9Thanks for looking.
bubblelover is offline   Reply With Quote
Old 06-22-2014, 07:31 AM   #2
Wlcome to the group.
Unfortunately there were two different size panels used. Here are links to two ads that show that panel, is it the large one or the small one you need, what are the dimensions of yours and is it missing or just damaged?
1970 16ft amerigo camper
Amerigo Fiberglass 16' Camper, lightweight
Old 01-15-2015, 10:12 AM   #3
Alabama
Amerigo F16 Gonna try
to answer with a picture and approx measurements. This cover is missing. I can probably make one for a "get by" but would rather have one that is made for it.
Measures approx. 21 1/4 by 35 1/2
Old 01-15-2015, 02:57 PM   #4
SteveV's Avatar
Trailer: Amerigo FG-16
J,
That looks like the same refrigerator door opening as my '72.
Honestly the "factory made" one is pretty crude, it's just a sheet of thin aluminum (think aluminum siding thin) with louvers punched in it then attached to an aluminum frame. It has screening on the inside to keep the bugs out. There is a hinge on the top of the frame similar to the windows, other than that there is no hardware to hold it open and 2 sheet metal screws hold it closed at the bottom.
I think someone with any fabrication abilities could easily make one just as good if not nicer that the oem part.
Mine actually has a split running horizontally thru the louvers due to how thin the panel is.
SteveV is offline   Reply With Quote
Old 01-15-2015, 03:49 PM   #5
Borrego Dave's Avatar
Trailer: Casita SD17 2006
J, just food for thought. There used to be a FG shell builder here in town. All the shells were blank moulds, any window openings needed were cut later. The cutout pieces were scrape to them. I picked up a few dozen for free and ended up using them for a number of FG projects. If you can find a maker close to you, you should be able to get a cutout piece large enough to make a nice door.
Old 01-15-2015, 04:17 PM   #6
Scamp sells "cutouts" I believe. But the need here is for a ventilated cover for the back of a refrigerator compartment.
Now, if the OP went to a compressor refrigerator, that would be an excellent idea
Old 01-15-2015, 09:26 PM   #7
Alabama
Amerigo cover
Thanks for replies. Have some scrap alum. and other materials and may try to make a cover. Having the louvers done may be a slight problem. Will need to shop around, but here in Birmingham shouldn't be a problem. I didn't know they were fastened down with screws.
This camper will be a project to redo. It is useable as is but won't win any beauty contests.
We have a 17 ft Casita Liberty deluxe we use when we get a chance.
Thanks again for the info.
Old 01-15-2015, 09:36 PM   #8
SteveV's Avatar
If you have any local old school hot rod or rat rod builders check with one of them.....they will likely have or know someone with a louver punch press.
Old 01-24-2015, 11:06 PM   #9
Roy in TO's Avatar
The louvers in post # 4 look very close in size to some fridge vents currently available. Links to upper and lower Norcold vents:
Happy Trails RV, Inc.
amerigo
1973 Amerigo For Sale in MN Billb Classified Archives 12 07-24-2009 10:14 AM
Amerigo FG-16 Screen door wanted Dennis R. Dorotinsky Classified Archives 0 07-01-2009 07:39 PM
16ft Amerigo $4000 Robin G Classified Archives 1 06-30-2009 05:58 AM
Amerigo 1971 Project Robin G Classified Archives 0 06-20-2009 09:05 PM
amerigo slide-in and amerigo on a dodge chassis Tim O'Toole General Chat 4 02-27-2008 09:11 AM
