Axle - Fiberglass RV
Old 06-12-2016, 08:45 PM   #1
Nevada
Axle
Hi.
I have questions about my axel. I thought I read years ago in the early 2000'stages that the older scamp axel could be filled or that someone had donenough it. I'made confused now since I read on the Facebook page you can't flip it. Can it be flipped? It would be easier for me if we could.
TIA
highlandsgirl is offline   Reply With Quote
Old 06-12-2016, 09:39 PM   #2
The Minimalist's Avatar
Louisiana
Being a Scamp, I have to assume that it is a torsion axle. It's true that a torsion axle can't be flipped. On a leaf spring axle the reason for flipping it is because it is bent and the tires are wearing. Sometimes if the bend is right, flipping returns the axle geometry to something approximating normal. These axles generally have a slight upward arch through the length of the axle.
What year is your Scamp and why do you think the axle needs to be replaced?
Clif
Old 06-13-2016, 07:13 AM   #3
Trailer: 2014 Escape 21
In the earlier model Scamps (I know before 1982) the S-13's had only 1200 lb. axles and S-16's had only 2200 lb. axles with 7" brakes. If you have and earley Scamp and the axle has not been replaced you are more than likely due for an axel change. The old axle has to be cut off and the new one welded on. You can count on a minimum of $500 depending on labor and options.
Eddie
Old 06-13-2016, 08:34 AM   #4
Boy you guys are doing a good job in answering the OP.. I have read that question six times and I still can't make heads or tails out of it.
Old 06-13-2016, 08:43 AM   #5
I went to Sherry's profile and captured this picture from her album. Her trailer is a 1983.
Old 06-13-2016, 11:06 AM   #6
This is a brand new Scamp. Brand new like 06-13-16. Notice the top of the fender well is at the top of the wheel rim.
Old 06-18-2016, 08:45 PM   #7
Nevada
Smile Funny!!
That's funny! I posted the question from my phone and it has a mind of its own. Lol it's cracked and not working right. I am also impressed all of you could read that. Haha thank you! I purchased a new axel and now is the fun part of figuring out the installation.
Old 06-18-2016, 09:49 PM   #8
Mike Magee's Avatar
Trailer: Li'l Hauley
Ummm.... what kind of axle did you buy?
When my Hauley's torsion axle was damaged by a hazard, I took it to a local trailer repair shop. They would've needed to carefully measure the mounting attachment dimensions and such to get the right thing, then they would've needed to have it custom made by a torsion axle mfr so it would fit... a process that would have taken weeks. Since I needed the trailer ASAP (to use for work), I opted to let them install a common, off-the-shelf spring axle with spring assemblies. They welded some new attachment pieces to the frame, and in 3 days I was using the trailer again. The spring axle did raise the trailer several inches, which has good points and bad points.
The fact that you've bought an axle already but are unsure how to get it attached makes me wonder... did you also buy a spring axle? Or did you buy an axle from the Scamp factory? Or something else?
I'm just one step away from being
filthy rich. All I need now is money.
Old 06-18-2016, 10:55 PM   #9
Nevada
I actually got it from another scamp owner. It's off a 2016.
Old 06-18-2016, 10:58 PM   #10
Nevada
I actually got it from another scamp owner. It's off a 2016. I'll let you know how it goes. We spent all day making sure we know how to install it. Working on it tomorrow.
Old 06-18-2016, 10:59 PM   #11
It may be welded on.
Old 06-18-2016, 11:17 PM   #12
Nevada
The old one is welded on so we'll cut it off and weld on the new bracket.
Old 06-19-2016, 08:47 AM   #13
Do yourself a favor, Bolt on the replacement. That way, because you will have to pay to cut it off you might as well do it right on the replacement and then in the future it will be quite easy to remove and replace it when needed.
Old 06-19-2016, 09:13 AM   #14
Mike Magee's Avatar
Yes, if one must weld, weld on some brackets with bolt holes instead of the axle assembly. But then, a new axle should last 20+ years, so it becomes an exercise in making the next owner's life easier.
axle
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
