Boler interior insulation and cushions - Fiberglass RV
Old 05-11-2014, 11:21 AM   #1
Trailer: Boler 17
Hi,
First time boler owner. Mine needs lots of TLC.
Parts of interior insulation missing, top bunk missing and all cushions for 17 boler.
Any help greatly appreciated. In Calgary, looking for cushion template.
Thanks in advance to help.
V
Newby boler owner is offline   Reply With Quote
Old 05-11-2014, 08:21 PM   #2
Trailer: 73,75,78 13' Boler 78 17' Boler
We have a 17 boler. We could let you copy our cushions to make a patern if you like.
Willys is offline   Reply With Quote
Old 05-26-2014, 11:20 AM   #3
Trailer: Surfside TM14 1975
I got a bunk set from the Trillium fellow here in Calgary however although the measeurments width wise were perfect could not use set as window placement in my Surfside did not match...brand new wood, foam and covers
Surfsider is offline   Reply With Quote
Old 06-04-2014, 08:33 PM   #4
Kelly H's Avatar
Trailer: '75 Trillium 1300
Washington, D.C.
This may help with the cushions.
http://bolerlife.com/cushiontemplate.html
Kelly H is offline   Reply With Quote
Old 06-05-2014, 04:31 PM   #5
Trailer: 1975 13' Boler
Saskatchewan
I don't have any ensolite for you however I do have a suggestion. When my dad got a Boler for me and my family it needed a PILE of work. There were some sort of creatures that were living in it before and some of the insulation had been scratched and torn to pieces. We cut out the damaged area so it was nice and square. Then we removed some of the original ensolite from inside the storage compartments in the dinette. Luckily there was enough there to patch the damaged areas. After sealing all the seams with caulking and painting the interior you can hardly tell it was damaged.
The plan was to then replace the insulation in the dinette storage with the thin foil lined stuff you can purchase at most home improvement stores. It wouldn't look the same however no one would be looking at it anyways in storage compartments. It has now been a whole year and I haven't replaced it though
Our original plan was to use some ensolite that we had ordered from Foammart. The stuff we ordered did not have a vinyl covering however after my dad had put a few coats of paint on it it seemed to look and feel very similar. We chose to go the other way because we knew it would match the same texture and look as the walls because it was the same stuff. Also we werent certain that the other stuff would hold up over time.
Not sure if this will help but may be something to consider
Theresa
thejanzens is offline   Reply With Quote
boler
Super sticky interior insulation!!! AuntHoodoo Problem Solving | Owners Helping Owners 14 09-30-2014 10:35 AM
Boler Interior Insulation dkohuska Problem Solving | Owners Helping Owners 7 05-29-2014 11:53 AM
Replacing Boler cushions with Scamp cushions? Jerry71 Problem Solving | Owners Helping Owners 12 07-17-2009 05:26 PM
Interior Vinyl/Insulation Stuff Chris73 Problem Solving | Owners Helping Owners 3 04-01-2006 06:26 PM
Interior liners / insulation Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 02-20-2003 02:03 PM
