boler windows needed - Fiberglass RV
Old 11-24-2018, 06:28 PM   #1
i am looking for 13" boler side Jalousie windows for a 1973. if anyone has suggestions/leads etc., anything would be greatly appreciated
morkfromork is offline
Old 11-24-2018, 08:18 PM   #2
scotty61's Avatar
What's wrong with the originals? If you're looking for new glass, I'm sure a glass place can help you out with replacing the panes (if it's the same setup as the ones on the Trilliums). Hope that helps.
Scotty61 - 1976 Trillium 1300
scotty61 is offline
Old 11-24-2018, 08:28 PM   #3
The problem seems to be with the inside of the window. The bottom angles towards the inside of the camper instead. So when it rains it goes into camper. Instead of forcing the rain water to be directed through the drain slits, leading it outside of camper.
Old 11-24-2018, 09:33 PM   #4
John in Michigan's Avatar
Chris, post a picture of your window. Maybe they are installed backwards. The Boler 13 side windows have a sill that slopes down on the outside, similar to a house window. Also, when the windows are opened they should slant out and down.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is online now
Old 11-25-2018, 07:39 AM   #5
+10 Sounds like the window is upside down.
thrifty bill is offline
Old 11-25-2018, 07:46 AM   #6
scotty61's Avatar
That could do it thrifty bill.
morkfromork: Which way do your windows open when you crank them? Out and up? Or out and down? If it's out and down, the windows are definitely upside down.
scotty61 is offline
Old 11-25-2018, 02:26 PM   #7
bullfrogeh's Avatar
Wink Upside down ?
Originally Posted by scotty61 View Post
Which way do your windows open when you crank them? If it's out and down, the windows are definitely upside down.
Whoaaah ! My '73 Boler 13' windows crank OUT and point DOWN !!! In Ontario, the rain comes DOWN, and it drips OFF, and AWAY from the cabin, just the way we like it !
bullfrogeh is offline
Old 11-25-2018, 03:44 PM   #8
scotty61's Avatar
That's what I meant... the bottom of the panes are pointing to the ground. I guess it didn't come through clearly when I typed it out earlier. Strange that... *I* knew what I meant! Lol
scotty61 is offline
boler, windows
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
Windows Needed Randy Bishop Classified Archives 3 06-07-2009 03:44 AM
door/windows needed Dan Quinn Problem Solving | Owners Helping Owners 7 12-30-2005 05:48 PM
door/windows needed Classified Archives 0 01-01-1970 12:00 AM
