Fridge - Fiberglass RV
Old 08-23-2015, 07:25 PM   #1
Trailer: trillium 1300
Fridge
Wanted: a 2 or 3 way fridge that would fit into a "75 Trillium 1300. Must work well.
BerniceBaker is offline
Old 08-24-2015, 08:28 AM   #2
BuzzBunny's Avatar
Name: Barry and Kathy
Trailer: 1975 Trillium 1300
Fridge listed on Kijiji Peterborough for $80. Might be worth a look. Listed 4 hours ago.
BuzzBunny is offline
Old 08-24-2015, 10:11 AM   #3
fridge
I can't find it. What should I be looking under?
Old 08-24-2015, 11:04 AM   #4
fridge
Thanks. Found it!
bb
Old 08-24-2015, 11:25 AM   #5
Always, always, always verify that it works before buying.
They can usually be set up for 120 VAC operation just by setting them on a level bench and plugging them in. As long as it works in one mode anything else can be fixed. Ask for at least an overnight cool down before looking.
Be sure that the boiler area is warm, scoundrels have been known to cool them down with ice water in a bucket to sell a bad unit.
Bob Miller is offline
Old 08-24-2015, 11:49 AM   #6
David Tilston's Avatar
I assume the fridge in question is this one:
3 Way Fridge | parts, accessories | Pembroke | Kijiji
That is an RM211, the fridge that is usually installed in 1976 to 1981 Trillium 1300's. If it works, that is a good price.
The earlier model was an RM24. They did not go all the way to the floor. The hole can be cut bigger. This is all assuming that you have the required vents on the road side of your trailer. If your trailer has a logo on the road side. You will have to source the required vents.
David Tilston is offline
Old 08-24-2015, 12:00 PM   #7
The RM-211 is a great refrigerator, BUT it has the early style cooling circuit meaning that it is more sensitive to leveling, a major reason why many are replaced, poor or no cooling from being run out of level. Look at the pic of the back. It has a square edged boiler cover, indicating the earlier design
It could still have a lot of years of use... BUT...
The RM-2193 is a bit newer, about the same size, and will have the curved boiler cover, indicating that it is the later design and is not prone to out of level operation problems.
BTW: If the seller even suggests that it needs a charge or kept upside down for a while to make it work better, walk away.....
Old 08-24-2015, 12:15 PM   #8
BuzzBunny's Avatar
12VOLT FRIG, FOR TRAILER Peterborough Peterborough Area
Date Listed 24-Aug-15
Price
$80.00
Address Oakwood, ON K0M
SMALL FRIG, GREAT FOR TRAILER OR VAN, works off 12 volt. frig is 20.5" h, 16.5"w, 20" deep. $80 obo; or trade call if interested . 705-432-3068
This is the one I saw.
fridge
Can a 2-way fridge become a 3-way fridge? Rob Carmody Problem Solving | Owners Helping Owners 13 06-24-2016 10:54 AM
Dometic fridge front panel Legacy Posts Problem Solving | Owners Helping Owners 5 05-06-2003 10:04 PM
DC Fridge Wiring Legacy Posts Modifications, Alterations and Updates 7 03-06-2003 11:20 AM
FRIDGE in 1977 13' Scamp? Legacy Posts Problem Solving | Owners Helping Owners 5 12-22-2002 04:56 PM
Fridge Auto-Ignitor Legacy Posts Modifications, Alterations and Updates 1 09-30-2002 08:18 AM
