Wanted: Front Window Cover '73 Trillium 13' - Fiberglass RV
Old 11-22-2018, 10:18 AM   #1
Trailer: Trillium 1300
I am looking for a front window rock cover for a 1973 Trillium 13 foot trailer.
Phil Reid is offline   Reply With Quote
Old 11-22-2018, 10:21 AM   #2
Im sure you know they are hard to come by and a lot of them are broken (particularly the panels). Good luck with the search.
Old 11-22-2018, 01:31 PM   #3
Kai in Seattle's Avatar
You can make them, you know?
You'll need one to look at, make a ton of sketches and make sure you get the right kind of hardware (a couple of hinges at the top and a latch at the center bottom, and probably some method of holding it up when parked for air and light) and I'd fabricate one or have a metal shop do it, or make a fiberglass or light wooden one, even some kind of plastic bin...the world is your oyster of you're starting from scratch!
We incorporated a piece of scrap Lexan into ours for a permanent, "bullet-proof" but I admit we had one in the first place. We found a double-jointed hinge and latch it down with a carabiner. We use a small curtain extension rod with rubber tips at each end to brace it up when parked.
Best luck with it--in a way, innovation is the most fun part of redoing old trailers.
BEST
Kai
AFTER: white pic: with new double-hinged hasp and Lexan panel window installed.
BEFORE: brown pic: without hasp at bottom. Rock shield had been screwed shut and had never been used; area was packed full of mud.
Semper ubi sub ubi.
Old 11-22-2018, 03:58 PM   #4
scotty61's Avatar
If your window cover frame is still intact, you can probably find sheets of hard plastic in any colour you want and just cut them to the right size (I would go with white for the sake of original look). You can probably source out the right Trillium decal for the centre pane right here on FiberglassRV.
Scotty61 - 1976 Trillium 1300
scotty61 is offline   Reply With Quote
Old 11-22-2018, 06:35 PM   #5
David Tilston's Avatar
If all else fails, try Trillium / Outback. Not the original style, but it will fit.
Trillium Trailers
Old 11-27-2018, 04:52 PM   #6
Trailer: trillium
New Brunswick
Hi I faced the same problem with my Trillium so I got an old cover off a Sprite Alpine trailer and miter cut each corner of the top & bottom rails to fit. Once done I cut the hinge piece also to the right length. The width /height was the same so that made the swap easier. I moved the divider pieces to space them equally then I cut each of the panels to the same equal size needed and installed them inside out. Used a fine tooth plywood blade in my table saw backwards to cut them , Go very slowly and use eye protection for sure. Looks factory, minus the logo in the center panel. I did paint the weathered inside with RV white to tidy up things. Duane
getaway1 is offline   Reply With Quote
Old 11-28-2018, 05:05 AM   #7
scotty61's Avatar
Would love to see a picture of the finished work!
trillium
Trillium front window cover seal? Bill Lindenfelser Problem Solving | Owners Helping Owners 7 06-08-2017 06:17 AM
Trillium front window cover- can I repaint the Fiberglass? Cassie Trill Care and Feeding of Molded Fiberglass Trailers 14 01-13-2017 10:26 PM
Boler front window cover J Jordan Problem Solving | Owners Helping Owners 3 07-05-2009 12:04 PM
1973 Boler w/ Front Window Cover Booker B. Problem Solving | Owners Helping Owners 2 03-04-2008 12:45 PM
Front window cover Legacy Posts Problem Solving | Owners Helping Owners 10 06-05-2003 08:22 AM
