Wanted: Front Window Cover for Boler 1300 - Fiberglass RV
Old 10-27-2012, 09:23 PM   #1
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
I am looking for a front window cover for my 13' Boler.
This would be the fiberglass cover to protect the front window.
Anyone got one?
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 10-31-2012, 10:42 PM   #2
Trailer: 73,75,78 13' Boler 78 17' Boler
You should just get the front cover from Scamp. If you live close enough drive there. Also if you do drive there I might want you to get some for me.
Willys is offline   Reply With Quote
Old 11-01-2012, 04:40 AM   #3
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: jmkboler...Failing getting one from Scamp you could find the cut out piece from the windows holding up your water tank under the dinette floor. Get just the hardware from Scamp and some edging and make your own. A piece of exterior grade plywood can hold the water tank in place.
Old 11-01-2012, 03:32 PM   #4
jkmboler's Avatar
Manitoba
Interesting idea, but the water tank was held inplace with plywood. I removed the water tank and replaced it with a tank inside the dinette bench seat years ago.
1974 Boler 1300
Old 11-01-2012, 03:45 PM   #5
Now In: Fiberglass Body Pieces → 19"x37" Gravel Shield
$65.00 (USD plus shipping & handling)
This is directly from the Scamp site.
CALL TO ORDER
Product Description:
Includes mounting hardware and medium scamp decal
CALL TO ORDER
Includes mounting hardware and medium scamp decal.
Old 11-01-2012, 05:45 PM   #6
bomni's Avatar
Name: Matt and Lindsey
Trailer: 1972 Boler 1300
Scamp wouldn't ship an upper cabinet to us in Canada (BC) as a heads up, not sure this is always the case but you might run into the same response.
Also (as Alf suggested) I don't think most Bolers use a window cut out to hold up their water tank, none that we have seen anyways (70's models in BC).
Does your front window need to be replaced? Because if by any chance it did, you could use it as a mold & create a cover with fiberglass if you are handy.
bomni is offline   Reply With Quote
Old 11-01-2012, 08:45 PM   #7
james kent's Avatar
Trailer: Boler 1984
The newer bolers made in Ontario have the water tank placed between the frame rails and held in place with the cut out as mentioned. This is the case with our '84 model. Also the window cover is moulded, similar to the scamp model. If they won,t ship to Canada then perhaps someone could bring one to a Bolerama gathering for you. There was some good interchange of parts at the Niagara Winefest this year.
Old 11-02-2012, 09:17 AM   #8
Borden's Avatar
Name: Borden and Carole
Some day will have to make it to a Bolerama gathering bet it was a lot of fun
1978 Ontario made Boler
Old 11-02-2012, 10:04 AM   #9
Originally Posted by bomni View Post
Scamp wouldn't ship an upper cabinet to us in Canada (BC) as a heads up, not sure this is always the case but you might run into the same response. .
In talking with Scamp on this topic they actually will ship to Canada but the problem is the cost is more than the cabinet is worth. They only use one way/mode for shipping parts and thats it - will not consider using a different/cheaper option of shipping if you ask.
Old 11-02-2012, 11:14 AM   #10
jkmboler's Avatar
Manitoba
Since Winnipeg is so close to the US border (1hr drive), there are several companies that provide a package receiving service. I plan on talking with Scamp to see if they will ship to one of these companies on my behalf. This way, I can pick it up relatively easily.
1974 Boler 1300
Old 11-02-2012, 11:59 AM   #11
Kent another option is to talk with the folks at Trillium in Calgary.They have been pretty helpful to a number of Boler owners. They may have something that works for you and you could have it shipped to you via GreyHound Bus parcel service which could be a lot cheaper.
Old 11-02-2012, 12:15 PM   #12
jkmboler's Avatar
Manitoba
If I am not mistaken, the Trillium uses a square cornered rectangular cover, with an aluminum frame and a corregated fiberglass insert panel.
If this is true, I think that is rather ugly and wouldn't consider putting it on my egg!
1974 Boler 1300
Old 11-02-2012, 12:54 PM   #13
Trailer: 2010 Escape 17B
You are thinking of the old style Trillium rock guards, if you look here
Trillium Trailers - The Outback - Photo Gallery you will see the new ones are all fiberglass, rounded corners.
Funny though as I am actually quite partial to the old ones but for a Trillium not a Boler.
kootenaigirl is offline   Reply With Quote
Old 11-02-2012, 02:49 PM   #14
Jim, you never know without asking but they might be willing to send you a blank piece of fiberglass in the correct side and you could put the trim on the edges any way you wish.
boler
Boler front window cover brownrecluse Modifications, Alterations and Updates 4 07-31-2012 08:04 PM
Front window cover Hazel in Sk Problem Solving | Owners Helping Owners 7 05-04-2012 05:30 PM
Boler front window cover J Jordan Problem Solving | Owners Helping Owners 3 07-05-2009 12:04 PM
1973 Boler w/ Front Window Cover Booker B. Problem Solving | Owners Helping Owners 2 03-04-2008 11:45 AM
Front window cover Legacy Posts Problem Solving | Owners Helping Owners 10 06-05-2003 08:22 AM
