Wanted: Furnace Parts Wanted or tips on repair - Fiberglass RV
Old 04-27-2012, 09:32 AM   #1
Dave Storey's Avatar
Name: Dave & Elinor
Trailer: Trillium 4500
Hi need some answers or guidance,
I have a dual-therm furnace model 65810-002 Trillium 4500 series 1976. Problem is the pilot light has a weak blue flame .When I hold in red botton to start for a minute or two it will not start because flame is too small.
a: I made sure there was no air in the lines by turning on the stove and the fridge which work great . I hooked up other full propane tank . Still the same problem .
b: I removed the tubing from pilot gas controller and blew it out plus the pilot itself .
Quickly pushed in and out red button on gas controller in to see if gas comes out, which it does .
c: reconnected everything and checked for leaks with soapy water - no leaks.
d: Tryed to light it again same thing, small flame
e : replaced thermo coupling and checked for leaks ,still same little blue flame problem .
f: No one sells replacement pilot light assembly or gas controller anymore as far as I know .
g: After what I have done just found out I am not legal to try to fix what I am trying to fix after I already did .Learn something new everyday already too late .
H: I guess I can't fix my barbecue next time even though they sell parts at the hardware store.
I : Now I am stuck
Conclusion :
A: Has anyone got any tips before I hire a furnace mechanic .
B: Does anyone know where I can get a replacement furnace at a good reasonable price ?
C: Maybe someone knows an answer .
Thanks
Dave
Dave Storey is offline
Old 04-27-2012, 11:09 AM   #2
David Tilston's Avatar
Dave,
A gas valve that works is available at the following web site. Search the first page for 41-0640.
Furnace Parts for Duo-Therm, Suburban, Hydro Flame
I would recommend that it is installed by a furnace mechanic.
Your furnace is a gravity furnace. This means, no fan, no electricity, no noise, just heat. The down side is lower heat output, and not as efficient as a forced air furnace. No one sells a gravity furnace anymore, and I for one think that is a shame.
Your trailer was designed to use that furnace. Changing to a forced air furnace would involve patching the hole for the exhaust/intake vent.
Check out the following links;
How to physically remove a heater ...
Duo Therm Furnace Settings
Also, if you do decide to replace it, please don't destroy it. Randy Bishop is looking for them.
http://www.fiberglassrv.com/forums/m...hop-16660.html
David Tilston is offline
Old 04-27-2012, 01:01 PM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Take it all apart and clean the spider nest out of it. Also remove the burner assembly and clean the nest out. Air won't do it, clean, clean clean.
Mike
mszabo is online now
Old 04-27-2012, 03:59 PM   #4
Name: Dave & Elinor
Should I take the gas controller apart and clean it first before I buy one ? Just curious .
Is there a pilot light that I can get out there because I think it is no good either .
The burner does work when I use a propane torch to heat up the thermal sensor while I push the botton in and then turn on burner .
The thermostat doesn't work because it eventually gets to hot in the trailer when set on low and eventually I have to shut it off .
Old 04-27-2012, 04:21 PM   #5
Name: Dave & Elinor
Oh by the way , what type of furnace is out there to replace the one I have incase I do buy one .
Old 04-27-2012, 04:29 PM   #6
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
If you decide to sell it let me know I "WANT IT".... I need a couple to re-install in (2) Trilliums I own..THANKS
Thanks David.....
Randy Bishop is offline
Old 04-27-2012, 04:41 PM   #7
Dan Meyer's Avatar
>snip<
>snip<
Why do you believe it is not legal for you to repair your trailer's furnace?
-- Dan Meyer :
Dan Meyer is offline
Old 04-27-2012, 06:15 PM   #8
mszabo's Avatar
Your valve is working fine. Take the pilot tube off and clean it out.
A spider has setup shop in that tube and your not getting enough gas.
Old 04-27-2012, 09:33 PM   #9
Get the tool for cleaning the tips of acetylene torches, it has many different size little wires for cleaning out small holes.
mary and bob is offline
Old 04-28-2012, 05:48 AM   #10
Name: Dave & Elinor
Randy I found this on kijiji if you want to check it out
RV Trailer Furnace - Ontario Parts, Accessories For Sale - Kijiji Ontario Canada.
Old 04-28-2012, 06:00 AM   #11
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Harbor Freight also sells a tiny set of round brushes for cleaning paint guns.
5 Piece Airbrush Cleaning Brushes
Thomas G. is offline
Old 04-28-2012, 12:18 PM   #12
Trailer: U Hall VT
Smile
I use a wire from the flags that they mark the utilitys with to clean out spider webs, works great!
Roger Kimble is offline
Old 04-28-2012, 02:27 PM   #13
Ardmore, Alabama
Has already sold..The owner said it came out of a Nova Camper.... don't know if it would have fit but doesn't matter now anyhow...But thanks for the lead........ RANDY
Old 04-28-2012, 02:39 PM   #14
Name: Dave & Elinor
Guess what ? I fixed the furnace after I took the tubing off the pilot then found out that the other nut comes off too . Feel kind of dumb though . Ole well .
Picture explains it all . Once I cleaned it out Wow what a difference like new again .
Thanks for the tips of clean clean clean and the cleaning tips .
Thanks everyone .
Sorry Randy . I will help look for other furnaces out there hope the one in Sudbury was the the one .
About the illegal part of it . The rv dealer told me that probrably to make me buy a new furnace to make money.
Thanks again
Dave and Elinor
furnace
Furnace Tips at Good Sam Site Darwin Maring Problem Solving | Owners Helping Owners 2 01-23-2011 04:44 PM
Faucet repair parts Steve Hilby Problem Solving | Owners Helping Owners 2 10-13-2010 01:39 PM
Furnace Parts? David H. Problem Solving | Owners Helping Owners 5 12-06-2009 06:43 AM
suburban furnace repair. (B1700) Herb P Care and Feeding of Molded Fiberglass Trailers 11 08-26-2007 04:45 PM
Wanted: 13' in need of repair Bob Cupp Wanted: Molded Fiberglass Travel Trailers 10 07-12-2007 07:37 PM
