Hunter compact jr specialty pin - Fiberglass RV
Old 03-07-2016, 10:12 AM   #1
Trailer: Hunter compact jr
Alabama
In restoring my Hunter, the previous owner had replaced one of the original pins for the accuride tracks with a nail! Here is a picture of one of the original pins. I was hoping someone might have a source or possibly one laying around their shop.
Thanks
Wade
Wade the K is offline   Reply With Quote
Old 03-08-2016, 10:16 AM   #2
Trailer: Compact Junior
Should be easy to fashion new ones......
Hi Wade
An allen wrench would be a step up from a nail.
I have my originals on chains and use magnets to keep them from dangling.
If I were to make new ones I'd buy the proper diameter metal rod and cut it into appropriate lengths.
Then I'd buy an oversized dowel and cut some short lengths of it.
then you can drill a hole in the dowel and epoxy the metal rod into it.
Paint or stain the wood dowel and then you have an attractive handle on your "keeper peg".
Another quick fix would be to get an appropriately sized bolt and thread a nut or two all the way to the head. That would give you something to pull on to take the bolt out for lowering the roof.
john madill is offline   Reply With Quote
Old 03-08-2016, 11:58 AM   #3
Alabama
I like the Allen wrench idea John, it would definitely be an improvement. I doubt I will ever find a replacement.
Thanks
Wade
Old 03-08-2016, 03:11 PM   #4
Trailer: Bigfoot B-17 CB
I'm not sure what dimension pin you need but if you google lynch pin I think you will find something that will work.
Old 03-08-2016, 05:16 PM   #5
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Wade, the pin in your pic is called a "ball spring release". Grainger & McMaster Carr carry them.
Old 03-09-2016, 09:20 AM   #6
Alabama
Thanks for the information everyone. Most helpful and got me on the right track.
Just a little info.....The pin that is in the camper is a 3/16"diam x 1"grip length that is stainless steel. Made by Hartwell.
Looks like Hartwell may distribute the exact same pin as Lockwell now. The pins are expensive, and hard to find an "exact" B-handle replacement.
See attached link for a knockoff replacement that I will probably end up purchasing.
http://www.ebay.com/itm/131657013893
Volvo European 7-pin to US 7-pin Ellpea in CA Towing, Hitching, Axles and Running Gear 51 09-18-2015 05:05 AM
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
