Wanted: Kitchen window hardware - Fiberglass RV
Old 02-28-2016, 04:20 PM   #1
Trailer: Boler 1974 13 ft
Hi, I am looking for the hardware for the small kitchen window in my Boler 1300. It will catch enough to close, but on opening it just flaps and hangs there. The glass and seals are sound. Thanks
Lisa in FL is offline   Reply With Quote
Old 02-29-2016, 08:45 AM   #2
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
You contact Ian? :
Complete Guide to 13′ Boler Fiberglass Trailers
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 02-29-2016, 09:31 AM   #3
jlbails's Avatar
Trailer: Boler 1977
Hi Lisa, I had the same problem in my 77 Boler. The arm needs to be fixed inside the rail. I found this small friction pad, $3.45, that worked well. Once I figured out how to insert it, it slides really well and keeps the window shut. Give it a try. Jamie
Nylon Friction Pad
jlbails is offline   Reply With Quote
Old 02-29-2016, 09:31 PM   #4
Does this only work on the small windows, or should I get some for my two other windows by the dinette? Might be worth it to have them and save some shipping?
Old 03-01-2016, 05:14 AM   #5
Ian G.'s Avatar
I am fairly sure you are looking for a R7032 Operator, Awning Window or Vent. Maybe search the internet for a closer supplier but here is an example I quickly found
http://www.doorandwindowparts.com/r7...rm-p-4015.html
or
http://www.technologylk.com/crl-awni...-lk-R7032.html
You may also find the operator is the same as those found on current roof vents, may be worth looking at your local RV parts department.
Old 03-01-2016, 09:03 AM   #6
jlbails's Avatar
Trailer: Boler 1977
Hi Lisa, I think the friction pad only works on the smaller door and kitchen windows with an arm that raises and lowers the window. The side windows have a knob mechanism, not an arm. At least that's what I have on my trailer. Yours could be different. I may have ordered other things at the same time as the friction pad to save shipping. I can tell you it was totally worth it! The friction pad works great. Because it is nylon, it should last a long while. Good luck!
Old 03-01-2016, 04:18 PM   #7
Thanks, I will look at my window s before I order. I am so happy to hear about a fix that works!
Kitchen or no kitchen? AJCmedia Modifications, Alterations and Updates 44 04-02-2016 03:25 PM
Lubricant for window hardware Randy J. Problem Solving | Owners Helping Owners 3 09-11-2013 08:34 AM
Window seals & hardware for 76 Scamp tilt out windows Jenny W. Modifications, Alterations and Updates 42 07-31-2013 12:11 PM
Wanted: WANTED - Trillium 1300 - Shelves, door window, kitchen window and frame David Tilston Parts: Buy | Sell | Trade 6 10-20-2012 09:13 PM
Window seals & hardware for 76 Scamp tilt out windows Steve Thomas Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
