Need Rear Stabilizers and spare tire holder. - Fiberglass RV
Old 05-23-2015, 07:57 PM   #1
SandyP's Avatar
Trailer: Past: 1983 13' Scamp; 1984 16' Scamp
I have a 13' Scamp but think stabilizers for any size fiberglass type camper would work. I'm in central NYS.
SandyP is offline   Reply With Quote
Old 05-23-2015, 08:06 PM   #2
Stabilizers are available from etrailer.com. and other sources. The adjusting rod has to be ordered separate, it's not included with the stabilizers
mary and bob is online now   Reply With Quote
Old 05-24-2015, 06:03 AM   #3
SandyP's Avatar
Thanks, Bob.
Old 05-24-2015, 07:05 AM   #4
From the Scamp factory, the spare is attached directly to the shell using three bolts. Plywood reinforcement fiberglassed to the inside of the shell carries the weight. I don't know exactly how it all goes together, since the inside is hidden under insulation and rat fur, but I assume the bolts go through plywood and fiberglass. Whether you could restore the original mount might depend on the condition of that plywood. Are there any remnants of that set-up on your trailer?
I don't know if there is another way to mount a spare. The tongue is pretty full, and the bumper pretty flimsy. You might do a Google site search for "spare tire mount" and see if there are any ideas on old threads.
Old 05-24-2015, 01:24 PM   #5
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
As he says.. look for the plywood reinforcement piece inside under the rat fur and insulation. It it is there, just drill out the holes, and get three long fully threaded 1/2 inch bolts nuts and flat washers. OR add your own plywood.
Wayne Collins is online now   Reply With Quote
Old 05-27-2015, 07:43 PM   #6
SandyP's Avatar
Hmmm,....I'm seeing two bolt spots.
Old 05-27-2015, 09:51 PM   #7
That would be right if you have an older unit with 4-lug wheels. Newer ones have a 5-lug wheel and mount with 3 bolts.
How did you build your rear mounted spare tire holder alan H Problem Solving | Owners Helping Owners 17 05-17-2018 12:31 PM
Scamp Spare Tire Holder? Bill Nolen Modifications, Alterations and Updates 30 04-17-2015 05:47 PM
Need Help:Spare tire and Rim Ana A in NJ Problem Solving | Owners Helping Owners 13 04-24-2012 07:52 AM
Spare Tire Holder Bonnie Towing, Hitching, Axles and Running Gear 18 08-30-2007 03:04 PM
Spare Tire Holder on a 16' UHaul Vacationer Kevin A Problem Solving | Owners Helping Owners 10 03-19-2007 12:18 PM
