Wanted: need used 30 amp surge protector - Fiberglass RV
Old 02-08-2012, 01:58 PM   #1
Trailer: Casita trailer
Hi, I just cant spend 50 to 100 dollars on a surge protector so Im wondering if some one has a good condition 30 amp one .Maybe you've upgraded to 50 amp or different model. Let me know. thanks gregd
gregd is offline
Old 02-08-2012, 02:19 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
A couple of thoughts.
I looked on my local Craigslist and saw at least one whole house surge protector for sale for $75. You may find something similar there or on eBay.
What components are you trying to protect? You might be able to use a smaller strip type surge protector mounted close to the vulnerable component(s).
Thomas G. is offline
Old 02-08-2012, 03:40 PM   #3
honda03842's Avatar
Name: Norm and Ginny
Surge Protector
We have never used a surge protecter in 1000s of nights of powered camping and have never had an issue. The only things in my trailer that might be an issue are the computers and possibly the TV. If it lightenings we usually unplug the computers and run on battery. If we're really worried about the TV we would do the same but never have.
I'm sure they'll be some one who will say they are necessary but in 11 years of 7 months a year camping we've never had a problem....
Just our experience
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is offline
Old 02-08-2012, 03:46 PM   #4
Check WallyWorld for inexpensive surge protectors and purchase an inexpensive surge protector for your Television and computer and don't worry about the rest.
Darwin Maring is offline
Old 02-08-2012, 04:50 PM   #5
Surge Protection
Leviton and Eagle did make a surge protection receptacle with replaceable protection element. They came in 15 or 20 amp versions and had the same footprint as a GFIC receptacle . The cost was about $15.00 each. I used them to protect electronic equipment at work and they worked well. I do not see the sense (Cost + Necessity) in adding surge protection for a whole trailer Your coffee pot , refrigerator and other appliances really do not need surge protection
steve dunham is online now
Old 02-08-2012, 04:54 PM   #6
electrical-receptacle-tester
Here is something that every camper should have. Use it to test the camp ground power receptacle B 4 you connect the camper.
It verifies that the camp ground wiring is compatible with your camper and in accordance with the electrical code.
Should you get a RED lite, do not connect because it could be dangerous to you and your equipment.
Electrical Receptacle Tester with GFCI Diagnosis
Old 02-08-2012, 11:42 PM   #7
Name: Laura & Rick
Trailer: Had an Escape 21 ft
Is there an adapter for this 20 amp tester to the 30 amp camp ground power pole?
Laura & Rick is offline
Old 02-09-2012, 06:56 AM   #8
Yes. Check Walmart or Harbor freight.
Old 02-09-2012, 08:31 AM   #9
Thomas G.'s Avatar
Speaking of Harbor Freight, there is always a 20% off coupon at this URL.
Digital Savings
Old 02-09-2012, 09:14 AM   #10
Tester
This is a fine tester for checking polarity (black to brass , white to silver ,bare to green) and for checking if a GFCI will trip at the proper current level . It will not test for loose connection or damaged receptacles causing arcing faults or for spikes, dips or surges in voltage . Darwin is correct that reverse polarity can be harmful to many pieces of equipment and dangerous to human safety as well . This tester is often used by electrical inspectors to test GFCI in homes (bath , kitchen ,garage ,outside) and receptacle polarity because it fits in their pocket , is easy to use,.hard to damage and cheap to buy.
Old 02-09-2012, 11:05 AM   #11
cpaharley2008's Avatar
This is like a whole trailer GFI protector, if there is/are any electrical issues it will turn off the power at the pedestal and prevent the problem from entering your trailer. It is a good investment for rv's without a lot of electrical appliances. Protects against surges and lightning spikes.
Technology Research Corp - Portable 30 amp GFCI Surge Guard with Shock Shield - 44740-004-012 - Surge Protectors - Camping World
However, if you have air conditioning and converters and leds and a lot of money invested in your electronics then you would want the next step up protection. This will not allow improperly wired CG electrical pedestals to send that bad stuff to your rv. It also protects like the above you from surges and spikes. In addition if hooked up and the CG has inadequate power and there is a brown out where your voltage drops below 110, it will shut off your power to prevent any electrical motors such as a/c from damage due to low voltage.
Technology Research Corp - Surge Guard 30 Amp Portable Surge Protector - 34730-001-012 - Surge Protectors - Camping World
cpaharley2008 is offline
Make-Your-Own Surge Protector Jane P. Care and Feeding of Molded Fiberglass Trailers 18 10-13-2011 07:57 AM
edge protector strips ronsmith100 Care and Feeding of Molded Fiberglass Trailers 5 04-02-2009 01:35 PM
Bumper protector Alistair Camelford Towing, Hitching, Axles and Running Gear 16 12-22-2008 02:17 PM
Surge Guard 30 AMP For Sale -$45.00- Tom T. Classified Archives 0 12-04-2008 02:36 PM
Why not surge brake? EricMeyer Care and Feeding of Molded Fiberglass Trailers 12 04-17-2008 07:11 PM
