Needed front window for a 74 trillium - Fiberglass RV
Old 10-17-2014, 11:44 AM   #1
I need a good used front window or window frame to replace my current one ...Click image for larger version
Name:	ImageUploadedByFiberglass RV1413567847.946971.jpg
Someone in Alberta have one ?
thriller triller is offline   Reply With Quote
Old 10-17-2014, 02:06 PM   #2
Trailer: 1977 Trillium 4500 (previously a 1978 Trillium 4500, Rpod 171 and Surveyor SV251)
Nova Scotia
Gosh that's a shame. How did that happen?
77 Trillium 4500
Phil 4500 is offline   Reply With Quote
Old 10-17-2014, 02:14 PM   #3
Stupidity...didn't double check if I put the keeper pin in on the hitch ...halfway home going downhill it popped off ...
Old 10-17-2014, 04:29 PM   #4
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Can you not get one from the Trillium Factory in Calgary?
Originally Posted by thriller triller View Post
I need a good used front window or window frame to replace my current one ...Attachment 77777
Rick Mooyman is offline   Reply With Quote
Old 10-17-2014, 04:29 PM   #5
Haven't checked yet
Old 10-23-2014, 11:56 AM   #6
David Tilston's Avatar
Where are you located?
Those rock guards are as rare as hens teeth. It looks like the outside frame is still OK, and can be saved. The rippled stuff that is missing is called Filon. It can be purchased new, or better yet used. The window sections can be replaced individually. Do you have any close up pictures of the damage? Inside and outside would be nice.
Your trailer came uncoupled at speed? Wow. What did the damage?
Old 10-23-2014, 11:58 AM   #7
Edmonton
Old 10-23-2014, 12:08 PM   #8
I will take a look at what I have. I might be able to locate some of the panes. It looks like two were broken.
Old 10-23-2014, 12:39 PM   #9
Awesome thanks ...the brackets are a little bent too
Old 10-23-2014, 02:59 PM   #10
Enquiring minds want to know!
Old 10-23-2014, 04:55 PM   #11
Name:	ImageUploadedByFiberglass RV1414104871.891729.jpg
ID:	78017it was just past Obed towards Edmonton going down a small hill ...the bike rack went through the window
Old 10-23-2014, 05:50 PM   #12
IllAnnoy
It looks like it can be fixed, take it apart and really assess the damage,
Flat glass is cheap and plexiglass is available.
Old 10-23-2014, 05:51 PM   #13
Thanks for the tip
Old 10-27-2014, 09:33 AM   #14
I don't see much bent aluminum. There is nothing special about the glass. It looks like it is totally repairable.
The rock guard looks to be missing one piece of aluminum. The vertical piece that separates the flat section from the clapboard section. Did you find that? The material that you need to replace the clapboard, (or flat) section is called Filon. You can get some at an RV scrap yard.
If the hardware is damaged, I definitely have some extra stuff you can use. I recently came into possession of several windows that are not the same overall size, but the panes are the same height, so the linkages should be the right length. PM me if you need parts.
trillium
1974 -13 ft Front Window Cover Needed TedN Classified Archives 0 09-19-2011 01:21 AM
1976 Triple E 14 Surfside Front window cover panel needed! AlbertaBound Hi, I am.... 1 08-20-2011 06:20 AM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
Needed: Front Window Rock Guard Ray and Patty Parsons Classified Archives 0 05-20-2008 11:11 AM
Trillium Front Gravel Guard Wanted/Needed Josh Henderson Classified Archives 0 11-02-2006 05:19 PM
