Free Original Axle from a 1971 Compact Jr. - Fiberglass RV
Old 09-23-2012, 06:25 PM   #1
Trailer: Fiber Stream
Post Original Axle from a 1971 Compact Jr.
Solid steel (not hollow tube) square axle, weighs 55 pounds
has moderate surface rust
61 3/8 inches total length
57 1/4 inches Hub-face to Hub-face
38 1/8 inches Spring-center to Spring-center
4 inch drop (normally mounted spring-under for low garage-able stance, or can be mounted spring-over for higher ground clearance)
4 threaded holes in each hub, spaced 4 inches apart, for 13 inch wheels
Includes:
  • 8 Lug bolts
  • 4 U-bolts
  • 2 square plates
  • 8 nuts
  • 8 lock washers
NOT included
  • leaf springs
  • wheels
NO BRAKE FLANGES (I bought a new axle with brakes)
Located in San Diego, California
Local pick up or You pay for shipping
Old 09-26-2012, 06:59 PM   #2
Trailer: compact jr
Hi! I won't know for a month or so if I need it.... I'll cross my fingers I don't!
K
KCan is offline   Reply With Quote
axle
1971 Compact Jr $2200 Camilla Referrals: Molded Fiberglass Trailers 1 11-16-2011 07:02 AM
WA | 1971 Compact Jr. Deb & Chuck Classified Archives 1 10-15-2011 06:11 PM
1971 Compact Jumior Jake Referrals: Molded Fiberglass Trailers 0 03-03-2010 04:18 PM
1971 Compact Jr Ebay Robin G Classified Archives 0 10-15-2009 03:58 PM
1971 compact jr. Larry Bryan Towing, Hitching, Axles and Running Gear 2 04-19-2009 01:11 PM
