Wanted: Scamp Two Burner Stove cover - brown tones - Fiberglass RV
Old 08-21-2017, 02:52 PM   #1
Trailer: 1992 Scamp 13'
I called Scamp and they only have a red-tone color stove cover, so I am looking for the older one that was brown to match my cabinet doors.
Please let me know your shipped price to Calif. 92220.
Thank you.
lisantica is offline   Reply With Quote
Old 08-22-2017, 03:42 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Just a thought Lisa but a number of folks have made a stove cover out of wood and use it as a carrying tray also. If my stock one was missing I'd probably do that but I only use the cover for some place for brewing the morning coffee as we use an electric drip pot. YMMV
Borrego Dave is online now   Reply With Quote
Old 08-22-2017, 06:35 AM   #3
Thank you BD, I may go that route, but was hoping for a genuine Scamp cover if possible.
Old 08-22-2017, 07:56 AM   #4
Trailer: 2008 Scamp 13 Std
In my opinion, the Scamp covers are big and rather heavy. If you really like the way they look, go for it, but I'm of Dave's opinion on this one. We just put a colorful plastic tray on top of the stove. It's lightweight, has multiple uses, and makes a great place to collect small items that usually go on a nightstand. During the day it sits on the table and at night it goes on the stove.
Old 08-22-2017, 08:57 AM   #5
I will likely get something aftermarket, but at this point I was wanting to get as many original equipment items as possible. Probably has something to do with having my first Scamp.
Old 08-22-2017, 01:01 PM   #6
Trailer: Scamp 2017 16-ft SD / FB
two burner stove cover
Your right on about making a stove cover. The one provided by Scamp is heavy and poorly made. A little pressure on the side will pop the cover apart. I made one that also could be use as a serving tray when need. The 40 or so dollars Scamp charges can better be use on something that will stand the test of time.
Henry
Houston TX
Scamp 2017 16ft FB/SD
Gattopuin64 is offline   Reply With Quote
Old 08-22-2017, 01:38 PM   #7
Trailer: Currently shopping
Red face Stove cover
I made one of white plastic cutting board. I cut pieces from a small thinner cuttomg board and hot glued them to the bottom of the larger board for legs. I cut the legs about 4in long and just tall enough to prevent it setting on the stove. I placed the legs to sit on the counter and bump against the stove so it will not slide around. Works and easy to make.
J Ron is offline   Reply With Quote
Old 08-22-2017, 02:29 PM   #8
Okay. Walmart came through $4.99. Not a perfect fit but close. Will allow for some extra prep space.
Old 08-22-2017, 04:06 PM   #9
Perfect fix Lisa .
Old 08-23-2017, 11:57 AM   #10
Lightweight, multi-functional, and inexpensive! That's a win-win-win!
Here's another lightweight, inexpensive solution we found for our Scamp: interlocking, stacking bins in the closet.
Old 08-23-2017, 01:25 PM   #11
Attachment 110600
Those bins look quite functional! Must find, Walmart?
Old 08-23-2017, 01:52 PM   #12
Big Lots, $3.50 each. You may have to search to find the right size for the closet. I carried the inside dimensions around for a while before I stumbled across these.
Old 08-23-2017, 01:56 PM   #13
Thanks Jon!
Old 09-14-2017, 07:36 AM   #14
I have found an original stove cover that matches my cabinets, so my search is over.
The tray from Walmart did work fine, but I just wanted that Scamp one. Silly as it seems, I like original parts when possible.
Brown ZG 003 Stove burner Trill 4500 Ian Pearce Problem Solving | Owners Helping Owners 3 08-05-2014 08:08 AM
Replacing a 2 burner stove with the full 3 burner/over combo - 2005 Bigfoot dkerr Modifications, Alterations and Updates 3 06-18-2014 07:09 PM
Two-burner stove cover? Bobbie Mayer Problem Solving | Owners Helping Owners 11 05-27-2011 02:02 PM
FOUND: two-burner gas stove for Boler François P. Classified Archives 6 11-10-2009 11:43 AM
Extra Casita Spirit Cushions - earth tones L Schmidt Classified Archives 0 09-23-2009 01:16 PM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
