Wanted: Uhaul utility access panel CT-13 - Fiberglass RV
Old 04-05-2013, 06:29 PM   #1
Higginra's Avatar
Trailer: CT13
Indiana
I am looking at replacing the access panel on the left side where water and electric hookup are. The door is torn off the one I have.
Higginra is offline   Reply With Quote
Old 04-05-2013, 06:43 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I think you will need to replace the whole hatch.
RV Water Center Fill Hatch from PPL - PPL Motor Homes
Old 04-05-2013, 07:17 PM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
I made a template and cut one out of aluminum plate.
I used aircraft revit's To attach a hinge and painted to match.
mszabo is online now   Reply With Quote
Old 04-05-2013, 07:59 PM   #4
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Man, I had no idea those things were so expensive.
D Davis is offline   Reply With Quote
Old 04-06-2013, 07:39 AM   #5
They are expensive, but last years and will last even longer if painted with Fusion paint before the install. Protect plastic from UVs, should be an all molded mantra!
I bought a water fill hatch from Hitch Anything. Check out this page starting about 1/3 down. Prices are much better! Hitch Anything - Hatches
Old 04-10-2013, 10:58 AM   #6
Higginra's Avatar
Trailer: CT13
Indiana
So far I have not been able to find one the correct size. Mine is 11 inches x 6 inches rough opening. Idea's?
Old 04-10-2013, 11:28 AM   #7
If its only the door you could make that out of 1/8" aluminum. Mine has the piano type hinge. Turn latches are available online or at a RV dealer. I used 1/8 aluminum for a storage compartment door and a drawer front.
Old 04-10-2013, 12:19 PM   #8
Thomas G.'s Avatar
The second to last item on this page has a 6 x 11 cutout.
JR Products
http://www.adventurerv.net/camper-mo...k-p-29359.html
Old 06-21-2013, 04:59 PM   #9
Higginra's Avatar
Trailer: CT13
Indiana
Possible Solution
In searching for a panel that size. I am considering putting a exterior shower access panel in it's place. So far it's the only panel I can find which provides both the door and the interior panel. Phoenix USA 377-I White Exterior Shower Box : Amazon.com : Automotive
Old 06-21-2013, 05:32 PM   #10
Looks like it would work, throw away the shower stuff, and it's free shipping. Install with hinge on top????
Old 06-22-2013, 07:01 PM   #11
rockead rob's Avatar
Trailer: U Haul CT 13
The shower access from Amazon looks like a great idea. I think I will be going that route myself. If the existing holes are going to be a problem, I will line the inside with a piece of thin PVC board to mount new water connectors.
rockead rob is offline   Reply With Quote
Old 07-28-2013, 06:25 PM   #12
Higginra's Avatar
Trailer: CT13
Indiana
After ordering it I found it doesn't fit the open hole very well. I will probable order the other door mentioned in this thread.
Old 07-28-2013, 06:46 PM   #13
I bought the shower box but have not tried installing it as of yet. I just finished installing a 6000 btu a/c under the front seat next to the door. I installed a power converter, group 31 battery and rewired both 12volt and shore power. I installed a larger fridge as well.
Next project is installing portable propane water heater and changing sink faucet for hot and cold water. I was going to use the shower box to create a shower on the outside of the uhaul.
What exactly is wrong with the shower box enclosure? I assume it's too small based on your response. Please elaborate.
Thanks,
Rob
Old 07-28-2013, 09:14 PM   #14
Higginra's Avatar
Trailer: CT13
Indiana
The cut out is not what I had expected and none of the holes were in a useful location for me. Additionally, I was planning on mounting it like Bob suggested but found that water would be a issue as it would run off the camper and into the box from the hinge and right into the camper. Additionally, i was removing the shower faucets hardware for my purposes. Maybe one of the ones that has no holes drilled already would have been better.
I am also upgrading electrical with a PD 4045 and two 6 volts batteries but am not done yet.
Uhaul 13: removed the solar panel Mouse Modifications, Alterations and Updates 8 03-04-2013 04:53 PM
Bigfoot Interior Panel Access Roger M Problem Solving | Owners Helping Owners 2 02-20-2012 08:19 PM
solar panel on Uhaul 13 CT Marty D Problem Solving | Owners Helping Owners 1 06-16-2010 04:49 AM
missing an access panel Billb Problem Solving | Owners Helping Owners 2 05-12-2008 07:43 AM
Outside access panel for Scamp & eletrical mods Ron Gaillot Modifications, Alterations and Updates 7 09-20-2006 08:24 AM
» Trailer Showcase
2011
brian m.
The Egg
KCMongo
