For Sale: UHaul Vintage Stove Vent Fan Motor - Fiberglass RV
Old 02-09-2013, 06:09 PM   #1
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Motor with fan blade and bracket. $10 plus shipping from Michigan. Draws 2.4 amps.
Old 02-09-2013, 10:05 PM   #2
Tuanis's Avatar
Trailer: 1986 Uhaul CT
Utah
Hm... Tempting. It works good? Not sure what's going on with mine, but it tries to work sometimes, but sounds like it's going to explode
Tuanis is offline   Reply With Quote
Old 02-10-2013, 03:36 AM   #3
Thomas G.'s Avatar
It works fine. I removed it to install a computer fan with less draw to better suit my camping style.
Old 02-12-2013, 06:14 PM   #4
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Tom, Mine worked fine until I rewired my camper, then...we were not sure how to wire it. It looked like some wires were cut and did not know the orininal configuration. So to make a long story longer...If I knew how to wire mine back up, no don't need yours but if I can't, might want yours. DUHH ...
D Davis is offline   Reply With Quote
Old 02-12-2013, 06:28 PM   #5
Thomas G.'s Avatar
Originally Posted by D Davis View Post
Tom, Mine worked fine until I rewired my camper, then...we were not sure how to wire it. It looked like some wires were cut and did not know the original configuration. So to make a long story longer...If I knew how to wire mine back up, no don't need yours but if I can't, might want yours. DUHH ...
Mine has rotary knob switches in the hood. One switch controls the light and one controls the fan, which just has a single speed. So, it shoud be straight forward. Let me know if you need it.
Old 02-13-2013, 08:19 AM   #6
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
It is not that hard to rewire. you may need some crimp on spade connectors. But in general the positive wire is wired to one side of one switch and a jumper wire from the first switch same side is wired to the other switch. From the other side of each switch take a wire to the fan or light. on the other connection of the fan or light take a jumper wire to the other one and bring the negative wire to that point. you can make jumpers with the blue plastic crimp on tap connectors. they make one that takes spade connectors or a plain one will also work. I am not a fan of those types but in this case it is the simplest way to explain it
If it worked before I suspect all you need to do is to make sure your positive and negative are hooked appropriately, You do have power to the location and you didn't blow a fuse when you rewired it.
Michael J.
mmeyer is offline   Reply With Quote
Old 04-11-2013, 07:55 AM   #7
Thomas G.'s Avatar
This fan is still available.
Old 05-23-2013, 12:24 PM   #8
Thomas G.'s Avatar
We have a few new UHaulers so I'm bump this,as it is still available.
Old 10-16-2014, 12:35 PM   #9
Trailer: 1984 13' U Haul
Newfoundland
I am assuming this is not available anymore ?
nuddernewf is offline   Reply With Quote
uhaul
For Sale: Stove Fan Crackedegg Parts: Buy | Sell | Trade 2 02-26-2013 07:38 PM
Uhaul parts for sale plus 1955 vintage rv stove coffeejohn Parts: Buy | Sell | Trade 12 01-21-2013 08:03 AM
ventline fan motor replacement biw314 Problem Solving | Owners Helping Owners 0 07-03-2011 08:37 AM
12v step down for fan motor Nate Problem Solving | Owners Helping Owners 9 04-29-2009 08:41 AM
Scamp stove exhaust fan (new) Rob_C Classified Archives 1 04-23-2006 06:55 PM
