Wanted: UHaul Double Circuit Breaker - Fiberglass RV
Old 07-17-2014, 07:22 AM   #1
Trailer: UHaul CT-13 1984
Does anyone have the double circuit breaker found on the UHaul 16' Camper they are willing to sell? If so, please PM.
Thanks
Lv4toys is offline   Reply With Quote
Old 07-17-2014, 09:14 AM   #2
Trailer: Casita 17 ft DLX SD
Breaker Mfg.
Thanks
Who is the manufacturer of the circuit breakers? Many Mfg of residential electrical panels and circuit breakers use a buss of similar design and though not code compliant their breakers are interchangeable. IE A Square D Homeline Circuit Breaker will fit in a Cutler Hammer (Eaton) BR style circuit breaker panel. Home Depot , Menards and Electrical wholesale house stock the most common styles of breakers. Purchase a non CTL breaker
Old 07-17-2014, 10:31 AM   #3
The mini panel was manufactured by Todd Engineering Sales, Inc. (no longer in business). It looked like they used a thermal circuit breaker. I am trying to add one additional line for the AC, but I want to keep the look of the original mini-panel.
Old 07-17-2014, 10:53 AM   #4
Residential circuit breakers are normally thermal magnetic .The Mfg of the circuit breaker should have its name shown on the individual breaker IE. ITE , Siemens
GE , Square D , Cutler Hammer, Zinsco , FPE , Challenger , Bulldog , Frank Adams ETC The cost to get a circuit breaker UL listed would be cost prohibitive for a small mfg of RV converters so all the ones I've seen use circuit breakers made by a major breaker mfg
Old 07-17-2014, 01:34 PM   #5
Steve; Pat wants the same breaker as was original equipment in the Uhauls which is a little push button type of thing that mounts on a 4" box. Ours was mounted on a box next to a ground fault single outlet on the end of the upper cabinet. I tossed it long ago as it was nowhere near adequate for the amount of power usage we needed in our camper.
Old 07-17-2014, 03:21 PM   #6
W W Grainger sells the round style pushbutton thermal overcurrent device .Rated for 15 amps and 250 VAC but it only comes as a SP device . The cost was under $3 but that was a few years ago
Old 07-17-2014, 04:44 PM   #7
luvrOlife's Avatar
Trailer: UHaul
Pat, you might try asking on the Uhaul group on Facebook. There may be someone who hasn't tossed theirs yet or is willing to toss it your way. Good Luck!
uhaulcamper.com
-Vanessa
....no matter where you go, there you are!
luvrOlife is offline   Reply With Quote
Old 07-17-2014, 05:30 PM   #8
Thanks... I did post on FB. I know it would be simpler to upgrade the system, but I am trying to keep the vintage look.
Old 07-25-2014, 01:57 PM   #9
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
I've got one with cord but, it needs repaired.
mszabo is online now   Reply With Quote
Old 07-25-2014, 02:16 PM   #10
Mszabo: great! Do you have a photo of it and what repairs are needed?
Thanks
Pat
Old 07-25-2014, 07:04 PM   #11
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Small aircraft use the same type of breaker and I would suspect are of a higher quality. Saw them on the float plane as we were flying back from the fly in lake last Sat. I googled and found several sources somewhat pricey
mmeyer is offline   Reply With Quote
Old 07-25-2014, 07:15 PM   #12
Thanks.... If I can't find an original UHaul breaker panel, I will likely upgrade to a new converter / distribution panel.
Old 07-25-2014, 07:18 PM   #13
honda03842's Avatar
Name: Norm and Ginny
I had a trailer that used breakers that were no longer manufactured and found used breakers on Ebay for a fair price and they worked.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 07-26-2014, 10:44 AM   #14
mszabo's Avatar
Here is a picture, I plugged it in and it works?
Breaker is out, push breaker in and it turns off circuit.
Let go of button in pops back out. Maybe a bad breaker.
25' cord.
$40 shipped.
uhaul
End of the Saga of the circuit board & circuit breaker mishaps Adrian W Problem Solving | Owners Helping Owners 1 07-22-2008 05:11 PM
circuit breaker Ken & Sherry B. Problem Solving | Owners Helping Owners 11 10-16-2007 08:18 PM
Circuit Breaker overload? TorreyT Problem Solving | Owners Helping Owners 10 05-20-2007 02:33 PM
Magnetek 6325 circuit breaker Yves Pelchat Problem Solving | Owners Helping Owners 2 09-29-2006 07:52 AM
Where does the circuit breaker go? Legacy Posts Problem Solving | Owners Helping Owners 7 07-17-2003 08:47 PM
