Window Stone Guard - Fiberglass RV
Old 08-29-2016, 01:33 PM   #1
Window Stone Guard
My Trillium Jubilee came without a stone guard and I want to make one or have one made. I would appreciate someone taking some pics of a good one. Close up of how it is attached to the trailer and how the mechanism works etc.. Are there aluminum angle pieces on top where the piano hinge is? How is it secured when down?
I have a sign company client that says they can make me one if I know what I want..
Thanks for any help
Wayne
Wizard765 is offline   Reply With Quote
Old 08-29-2016, 02:53 PM   #2
IllAnnoy
I don't know if this will help much , but its what I have...
(click on it to enlarge)
Old 08-29-2016, 03:09 PM   #3
Here's some info that may help you:
Trillium Rock Guard Dimensions
finished Trillium rock guard
Replacing Trillium Window Rock Guard
Old 08-29-2016, 03:52 PM   #4
Thanks Donna
Those links helped.. I'm not sure but I think I might use some sort of piano hinge instead of the original channel with a screw in it.. Just need to figure out how to mount it.. Might use gas shocks instead of the aluminum channel and wing nut to hold it up.. Then I have to figure out a securing method for when traveling. It's all starting to come together in my head.. now I have to actually make it happen..
Old 09-11-2016, 12:36 PM   #5
Trailer: Trillium Manufacturing
Trillium Window Guard - Coming
For all those needing a new window guard for their vintage Trilliums....
I've decided to make a new mold and make a small run.
Please see the website.
TrilliumRV.com
Thanks
Tom
TomA is offline   Reply With Quote
Old 09-11-2016, 02:14 PM   #6
Tom:
This would be great.. Do you have a price in mind of what it would cost us?
Old 09-11-2016, 03:23 PM   #7
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
As I recall from looking a various photos of stone guards for one of them the piece on the wall of the trailer was a widely available awning extrusion. Then they used an interface extrusion that slid into that channel. Because it is a rounded shape it acted as a hinge. They did put stop screws into each end to keep it from sliding sideways.
A hinge knuckle from a hinge that was taken apart is one potential interface piece coming from the frame of the stone guard that could fit into the awning extrusion channel. There are hinges made with removable pins that can be in hardware stores. They are sometimes called loose joint hinges. There are also lift off hinges. All of those would work as they provide a knuckle at the end of a flange with holes drilled into it. You can get them in stainless steel.
This is a very simple solution using widely available parts. Not my invention, I am just reporting on how I saw it done.
FOUND - Trillium Window Stone Guard Wanted michael 01 Classified Archives 10 05-10-2009 03:08 PM
Wanted: Fiberglass front window stone guard Craig B. Classified Archives 0 03-22-2009 08:58 PM
Window Stone Guard james kent Problem Solving | Owners Helping Owners 4 12-19-2006 07:47 AM
wanted stone guard for window Erik J Classified Archives 12 02-24-2006 09:09 AM
Front Window Stone Guard Legacy Posts Problem Solving | Owners Helping Owners 16 05-11-2003 10:54 PM
