Changing Username - Fiberglass RV
Old 03-13-2008, 09:44 PM   #1
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Hello Moderators,
I notice that I have a distinctly lowercase username so I decided to go and change it from bookerb to Booker B. to fit in with the rest of the crowd - however I can't see where to do it anywhere... I even had my fellow programmer at work take a look as we tend to go a little blind after 8 hours in front of the screen.
Is this locked down for a reason - usually most bulletin boards assign a unique id to each member record and the username can be edited. I am more curious then anything else =).
I have to say, though, that after all the forums I have deployed and hacked together this is probably one of the best ones I have used.
Old 03-13-2008, 09:49 PM   #2
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Booker B.
OK, you are good to go.
Old 03-14-2008, 04:37 AM   #3
This powerboard software is a bit different, and yes we were hacked big time in 2005
Thanks for the compliment!!
Old 03-14-2008, 10:10 AM   #4
Booker B.'s Avatar
Thanks for the username change =)
Old 03-14-2008, 08:56 PM   #5
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
....Welcome back booker
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
What signs that a gas regulator needs changing? TonyB Problem Solving | Owners Helping Owners 1 04-17-2009 06:47 PM
changing tires cyndi H Towing, Hitching, Axles and Running Gear 8 09-17-2007 12:27 AM
Changing LP regulator Legacy Posts Problem Solving | Owners Helping Owners 10 07-02-2003 08:04 PM
