Document Center Not Working? - Fiberglass RV
Old 05-03-2006, 08:58 AM   #1
Trailer: 2004 13 ft Scamp
What's the deal???
When I go into the document center and try to go into the wireing diagrams for the scamp.................. It won't open. I have used it before. But it seems to be gone now.
Can others open it or is it just my problem?
Help please.
Thanks Bob.
bobtrower is offline   Reply With Quote
Old 05-03-2006, 09:50 AM   #2
CarolnJim's Avatar
Trailer: 2002 17 ft Casita Liberty Deluxe
Hi Bob
No problem here... it opened right up.
CarolnJim is offline   Reply With Quote
Old 05-03-2006, 12:01 PM   #3
Hi Bob
Thank you CarolnJim,
It seems I can open all the links except what I want. I am trying to find the Trailer to tug wiring.
Bob.
Old 05-03-2006, 09:23 PM   #4
Administrator
Mary F's Avatar
I got it, too, Bob. It's a PDF. I don't suppose you've recently changed or reconfigured the browser you use? (Your browser accepts pop up windows, right?)
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Mary F is online now   Reply With Quote
Old 05-04-2006, 06:29 PM   #5
Brian B-P's Avatar
Pop-ups shouldn't be a problem with these documents - they're direct links to PDF files.
The 7-pin wiring diagrams were built in an Acrobat version higher than 5 (probably 6), so in Reader 5 they produce a warning message, but still display properly. An even older Acrobat Reader (either separately or as a plug-in into the browser) may not display them at all. Every document in this section of the Document Centre is a PDF, so if the other ones work and these two fail, then I would suspect that you just have a very old plug-in; fortunately, that's a free upgrade from Adobe.
adding to the Document Center Kevin Horner Forum Admin, News & Announcements 1 04-02-2007 01:30 PM
Grand Opening of the Document Center Donna D. Problem Solving | Owners Helping Owners 18 06-03-2006 07:48 PM
