Mobile App Link Failure - Fiberglass RV
Old 01-31-2014, 12:16 PM   #1
kdhanso's Avatar
Hi,
While using the mobile app with my iPhone, I am getting failures when following links to other forum entries that are posted within a message. For example, the following thread in message #21 has a link to a rally.
New Member
When I tap to follow the link I get the message "Oops.. Network error. Refresh to retry." Of course, refresh gets the same message.
When I use a browser (Safari on the iPhone) the link works fine.
I'm not sure what can be done about this but any help is appreciated.
Thanks
Ken
kdhanso is offline   Reply With Quote
Old 01-31-2014, 05:54 PM   #2
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Ken,
I primarily use my iPhone (4s) to access this forum, and I have not experienced any of the problem you have described. My guess would be that it is a result of something in the settings, probably under Safari (e.g., accept cookies. I could not do online banking with my bank's mobile app until I changed some of the settings. Just a thought.
Old 02-01-2014, 06:15 AM   #3
kdhanso's Avatar
Hi Carl,
Thanks for the reply. When using your iPhone do you use Safari or the app? As I said, Safari works fine so I don't see how changing Safari settings would help. The link failure occurs when using the Fiberglass RV mobile app. It would be helpful if you (or another app user out there) would try to verify the problem using the thread I linked above and try the link in message #21 to see if it works or not.
Thanks
Ken
Old 02-01-2014, 06:25 AM   #4
CPW
CPW's Avatar
Hi Ken,
I did try the link you provided and it loaded with no problem using the app. I just know that my bank's app would not work without changing Safari settings. Which iPhone do you have? Also, the iPhone has some quirks. Try removing the app and reinstalling it. I have found and I don't know why but when my phone won't connect to WiFi systems, turning on Airplane Mode and then turning it off often corrects the situation. Check in Safari settings to see if you accept cookies.
Old 02-01-2014, 06:39 AM   #5
kdhanso's Avatar
Thanks Carl. I have the newer iPhone 5s. Current Safari setting is Block Cookies from third parties and advertisers (default). I tried block cookies - never with no luck. I also tried this using my wife's iPad and had the same link failure so it's not iPhone specific. I should note that not every link in a message fails, so far I've only run across this problem with links that are within the forum. I will try your app reinstall suggestion.
Ken
Old 02-01-2014, 06:48 AM   #6
kdhanso's Avatar
Just reinstalled app and still no luck.
Ken
Old 02-01-2014, 11:39 AM   #7
Administrator
Mary F's Avatar
For what it's worth, I get the same result with the app on my iPad.
I agree it's weird; hopefully it won't be hard to fix, since it seems to just be internal links that are the problem.
Thanks for the heads up!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 02-01-2014, 12:06 PM   #8
kdhanso's Avatar
Thanks Mary for confirming this. Now I know I'm not alone and that at least two of us are seeing this.
I'm happy to participate in any testing if you try any changes thing on your end. I did further tests using David's Trillium Serial Number thread Serial numbers on a Trillium as it contains lots of internal links. I had failures on some but saw nothing consistent that I could put my finger on.
Hope you find something.
Ken
Old 02-01-2014, 12:31 PM   #9
Administrator
Mary F's Avatar
Ken, I'm not getting any failures on the links in the trillium thread. Can you help me with those?
Old 02-01-2014, 12:42 PM   #10
kdhanso's Avatar
The app takes me to the end of the thread so I try opening the link in post #240 and it fails.
Going back, post #239 fails
#238 works fine.
#237 fails etc.
#234 has a link that works.
These are all internal links to the site.
Ken
Old 02-01-2014, 12:50 PM   #11
Administrator
Mary F's Avatar
oops, sorry. They weren't failing for me because I had switched to Safari.
My bad.
Old 02-01-2014, 01:01 PM   #12
kdhanso's Avatar
That's funny
Ken
Old 02-12-2014, 03:55 PM   #13
kdhanso's Avatar
Just checking back. Was anything found on this issue?
Ken
Old 02-14-2014, 09:33 AM   #14
Administrator
Mary F's Avatar
Hi, Ken. Between uninstalling the app and doing the reinstall, did you also cycle down your device?
I'm afraid this is going to turn out to be a Tapatalk issue. One thing I noticed is the internal links aren't displaying the same way on the app as they do in Safari (computer or app version). This indicates something odd in the way these links are parsed by Tapatalk's app. I'm afraid all we can do is report the issue and hope it's fixed in an update... and access the site via the Safari app if/when a thread has a bunch of internal links.
Failure of Axle Brackets on Scamp 5W Trailers Pete Dumbleton Towing, Hitching, Axles and Running Gear 43 04-03-2017 06:14 PM
Mobile App Change Coming Soon-ish Janet H Forum Admin, News & Announcements 6 12-20-2013 06:05 PM
Hensley arrow failure Kenorie Towing, Hitching, Axles and Running Gear 7 07-17-2012 05:16 AM
tire failure while driving 55 (ish)mph Flygal General Chat 9 06-24-2009 06:27 AM
