Positioning Emoticons - Fiberglass RV
Old 11-28-2005, 10:13 AM   #1
Administrator
Mary F's Avatar
Post
With the upgrade, I just noticed that if you click on an emoticon, it is inserted at your cursor position. (Before, for those of short memory, emoticons were always added at the end of your text block. You had to either think ahead or cut & paste.)
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 08-27-2006, 10:05 PM   #2
Catherine H.'s Avatar
Trailer: 82 14 ft Surfside Triple E TM14
I'm having trouble using the emoticons. I have the ENABLE EMOTICONS box checked, but if I try to put one in when posting, it just gives me text descibing the emoticon. What am I doing wrong?
Catherine H. is offline   Reply With Quote
Old 08-27-2006, 10:33 PM   #3
Gina D.'s Avatar
West Coast USA
Nothing. The text you see is the "code" that is read by everyones browser and it shows as code when you are writing your post.
After you actually add your post to the forum, the code turns into the smiley for all to see.
Old 01-19-2007, 12:38 PM   #4
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
aaahhhh
Larry&Carrie is offline   Reply With Quote
Old 01-19-2007, 02:37 PM   #5
Everyonce in a while you'll see a bunch of code where a smilie should be in a post. It's important to remember to hit the spacebar BEFORE placing a smilie...if you're doing it at the end of a sentence, etc.
Otherwise the coding gets confused
GPS-global positioning system Kevin K General Chat 24 11-13-2009 03:32 PM
Split Topic from GPS-global positioning system bbuehler General Chat 7 11-11-2009 10:30 AM
