Timbren Axle-Less - Fiberglass RV
Old 06-26-2015, 12:45 PM   #1
Trailer: In the market
Illinois
Timbren Axle-Less
Has anyone installed a Timbren Axle-less system on a Scamp 13'?
I have to replace my current axle, a Duraflex 1200 lb, on my 2008 Scamp 13'.
I am seriously considering the Timbren Axle-less with 7" electric brakes available at etrailer.com.
I would appreciate any info. Will the Scamp frame tolerate the torsional stresses at the attach point? Go to etrailer.com to view the Timbren-axle-less products.
Thanks,
Jerry
jerry28 is offline   Reply With Quote
Old 06-26-2015, 02:19 PM   #2
Trailer:
The Timbren system seems to be becoming a 'fashion' choice, though it's hard to see why it's any better than a rubber torsion system (which it nearly is).
Under a Scamp frame, it would be necessary to add the square tube cross-member that Timbren advise, so it becomes a build-it-yourself full axle.
Old 06-26-2015, 03:28 PM   #3
The Minimalist's Avatar
Louisiana
I could see this as an possible choice if you were building an off road trailer ground up, but although it says no welding, reading the install instructions means no welding after all the modifications(welding) is done.
Clif
axle
Axle-Less AxleLess Suspension - TIMBREN franck2cv Towing, Hitching, Axles and Running Gear 134 05-29-2018 10:56 PM
Best (easiest?) way to lift a Scamp 5er - New axle vs Axle-Less Trailer Suspension dreschool Towing, Hitching, Axles and Running Gear 7 06-26-2015 04:28 PM
Timbren Axle-less Suspension on Acorn ??? NancyS Towing, Hitching, Axles and Running Gear 7 08-05-2013 05:06 PM
Tank less water heater Denis Richard Plumbing | Systems and Fixtures 17 08-16-2006 04:20 PM
Egg-less In Arizona Legacy Posts General Chat 4 06-18-2003 11:45 AM
