www.ispbin.com uses an invalid security certificate. - Fiberglass RV
Old 05-16-2008, 01:05 PM   #1
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Hi Mike,
You may already know about this but I am getting the following error from the SSL Cert on ispbin.com when hitting your donation link:
Secure Connection Failed
The certificate expired on 03/04/2008 1:06 PM.
(Error code: sec_error_expired_certificate)
* This could be a problem with the server's configuration, or it could be someone trying to impersonate the server.
* If you have connected to this server successfully in the past, the error may be temporary, and you can try again later.
I don't know if this is even your responsibility as it's an outside merchant. I deal with this quite a bit at work - generally most people would ignore a popup error in the IE 6 and FF2 browsers but both IE 7 and FF3 totally stop the page load and you have to make an exception to load the page.
Cheers,
Booker
Old 05-16-2008, 02:23 PM   #2
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
Thanks Booker.
I decovered that a couple days ago and will be buying a new certificate.
As an alternative, you can use PayPal if you like.
Thank You,
Mike
SECURITY Roger C H General Chat 13 09-07-2009 12:36 PM
Trailer Security james kent General Chat 5 10-27-2008 08:04 PM
Security Greg Conly General Chat 21 04-15-2008 10:45 PM
Travel with Rabies Certificate General Chat 0 12-31-1969 07:00 PM
