FT through NJ winter in Casita? - Page 2 - Fiberglass RV
Old 10-19-2015, 11:01 AM   #15
Trailer: Bigfoot B-17 CB
I have been told by several very knowledgeable people that a 100 watt light bulb of any type puts out the same amount of heat. Those special "heat lamps" only cost more money and tend to be very fragile. Some heat lamps do concentrate the heat into a smaller area.
The 130 volt ones that I mentioned in my earlier post put out a little less heat than a 120 volt unit because they are running with lower voltage but they last a long tome. I used the same ones in my boat for years. I was curious to know if my second stage lamps were ever on so what I did was put a small drop of candle wax on one bulb and found out the second stage heat was needed at times.
casita
Looking for a good closet AC install walk-through Stacy Crotser Modifications, Alterations and Updates 13 07-27-2014 10:20 PM
Crack "Through and Through" Hatchway Mr Jimmy Modifications, Alterations and Updates 13 01-10-2014 11:33 AM
I was driving my '76 Boler through Texas and found... Eric Steven General Chat 5 07-26-2008 06:03 PM
Since You Can't Tow a Camper Through the Snow... Buck62 General Chat 5 02-05-2007 06:09 AM
"And a Rivet Runs Through It" Kristi Warner Modifications, Alterations and Updates 43 02-04-2007 03:14 PM
