the risk of stagnant water in a holding tank? long periods? Don't you have a drain?
disinfecting water involves adding a certain amount of chlorine to a certain volume of water….24 hours later testing is done….in a random sample if 4ppm CL is observed (called residual cholrine) the water and its vessel (water line) is disinfected…deemed safe for human consumption…..if 4ppm CL is not observed the whole procedure has to be repeated (something organic in the line/water absorbed the CL)
we are starting with a clean tank (either your trailer is brand new or you dumped a gallon of CL in there once and then flushed it a bunch of times) and clean water from your tap at home…
4 ppm is like: four inches in 16 miles, four seconds in 11.5 days, four minutes in two years, or four cars in bumper-to-bumper traffic from Cleveland to San Francisco….or to put it yet another way.... if you had four pounds of chlorine (what’s that? A couple of quarts?)… you could treat/maintain the 20 gallon tank in your trailer SIX THOUSAND TIMES (full fill-ups)….before you ran out of chlorine
A couple of drops every other fill-up not enough???… I’m most probably overdoing it (unless a mouse crawled into my tank when I wasn’t looking
Maybe if I lived in California, with the water challenges you guys have to face, I’d be a little more concerned but…the numbers are the numbers.
