Wi-Fi technology while on the road. - Page 5 - Fiberglass RV
Old 10-17-2007, 11:38 PM   #57
Lance MacArthur's Avatar
Trailer: Boler 13 ft 1972
Just catching up with the forums.
Pete -- what I did was return the 9 dbi omnidirectional antenna and ordered the 15 dbi omnidirectional from Radio Labs. Have been experimenting with placement, height and trying to avoid obstructions. Where I am right now, the setup increases the connection speed a lot. Through the Buffalo software, I see many more hot spots, and their strength is dramatically increased. Like from one or two bars to 4 and five bars.
The reason we went with this setup, is that it allows more than one computer to be hooked up to one spot, which is nice in situations where we can use the antenna to get a stronger signal.
The 15 db antenna is a lot bigger than I expected -- nearly 4 feet tall, and requiring a sturdy pole for mounting. I'm hooking it to a tall adjustable paint roller pole, and then using bungee cords to steady it. Seems to be working ok. Claims to have a 1.5 mile range, but I haven't seen anything close to that yet, unless it has a totally clear line of site (no obstructions).
So is it worth it? Marginally so far, but it might find a permanent placement at our winter home.
Lance MacArthur is offline   Reply With Quote
Old 10-19-2007, 10:24 AM   #58
Trailer: Scamp 13 ft
perhaps a christmas present for the man who has everything?
wifi detector shirt:
http://www.thinkgeek.com/tshirts/generic/9...g=cj&cpg=cj
gillian s is offline   Reply With Quote
Old 10-19-2007, 10:28 AM   #59
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
OH WOW! I don't have wifi on any of my toys and I still want this shirt!
(Remind me again why I'm still single...?)
Also,
Old 10-19-2007, 11:03 AM   #60
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I want it, too!
Don't you have dogs? Mine always buy me nice Christmas presents.
Bobbie
Old 03-16-2008, 03:52 PM   #61
Pete Dumbleton's Avatar
Here's a thread on RV.NET Technology Forum that will be of interest. I copied the starting post:
QUOTE
I have spent many months trying to find the best allround solution for getting WiFi service into the RV including custom routers, bridges etc and I have just come across the best solution bar none!
It's a Long Range USB adaptor ($50) and a Super Cantenna ($40).
We are at 1000 Trails in Las Vegas and anyone who has stayed here knows just how bad the WiFi service is, only available by sitting outside the store with a laptop.
I'm sitting here about 150 yards away from the store with the cantenna sat on the table inside the RV with a signal strength of -51 dBm. I'm seeing a 400kbps download and 250 kbps upload - totally unheard of.
In addition I have an active USB extender if I need it to move the unit outside to get even better signal strength.
The USB Adaptor is a high power 200mW unit from EnGenius and I bought it from www.newegg.com - the Super Cantenna came from Frys Electronics.
END QUOTE
Adapter
High Output Power up to 200mW (23dBm)
Super Cantenna
# 12 dBi gain
# 30-degree beam width (approximate)
BTW, the adapter is USB, so it can be just stuck out the window with its own antenna for simple setup or used with the cantenna or other antenna like the ones previously mentioned here.
The advantage to using a program like Netstumbler over Windows Zero Config is that you can set it up to refresh itself every few seconds while aiming your antenna for best signal. When set, close NS and open Windows.
The thread above mentions WiFi SiStr which shows updated signal strength but is not controlling the adapter. Haven't tried it yet.
Old 03-16-2008, 04:13 PM   #62
I use Netstumbler while driving around the local community. After surveying a given area I can select an available open W-Fi access point and connect while sitting inside the Escalade.
When we were in Chief;and, FL we were using McDonalds Wi-Fi. After two days of free access, all of a sudden it switchs you off to a pay-for-access ISP. Needless to say I just moved to another location, the Holliday Inn nearby.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 03-16-2008, 05:39 PM   #63
peterh's Avatar
The Cantenna concept has been around a long time. You can find complete directions for making one yourself in O'Reilly Media's Wireless Hacks book. A good alternate resource is the How To Build A Tin Can Waveguide WiFi Antenna page online, which gives you exact details for building one.
--Peter
Old 03-16-2008, 08:12 PM   #64
Yes -- I put the super cantenna link in there because the two together gives an excellent off-the-shelf package for $100.
I noticed that one of the omni-directional antennas previously discussed (about 11dBi) has a radiation pattern diagram and doesn't appear to be very omni, so that one could probably use some turning to get best results.
I may try one of tin cans myself, plus maybe a Yagi, in or out of a can. The other day, I cut a hole in the bottom of a large coffee can so I could stick my Hawking wifi adapter in it and that greatly improved my signal. I was able to identify 30!!! wifi signals from my balcony in Netstumbler, although most of them are weak.
There are three open wifi's (two cafe's and a city system) within a quarter mile of me, but all are behind buildings and not in my line of sight. If I can set up something directional enough, I may be able to pick up a reflection or knife-edge effect signal.
Hoping to find a used sat-TV dish to mount a wifi antenna at the focus.
Old 03-17-2008, 12:23 AM   #65
Greg A's Avatar
Trailer: 2015 Escape 19
I'm sitting in a state park on the side of a mountain in northern AZ and caught a signal with the WaveRV
I don't know if it is the best solution out there, but it is simple, compact and has worked very well. I just got out three reports that were due in the morning so it just earned every penny I spent on it....
If this keeps up we can stay out all week...
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 03-17-2008, 02:24 PM   #66
I'm NOT knocking the Wave, but the EnGenius EUB-362 EXT (datasheet PDF)has these specs and costs the same without the $100 part in front:
Available Transmit Power (Typical without antenna):
2.412~2.472GHz (IEEE802.11g)
22 +/- 1dBm @ 6 ~ 24Mbps
21 +/- 1dBm @ 36Mbps
20 +/- 1dBm @ 48Mbps
19 +/- 1dBm @ 54Mbps
2.412~2.472GHz (IEEE802.11b)
22 +/- 1dBm @ 1 ~ 11Mbps
Max is 200mW
Receive Sensitivity (Typical):
-92dBm @ 6Mbps
-76dBm @ 54Mbps
-92dBm @ 11Mbps
-96dBm @ 1Mbps
Antenna (2dBi)
Wave specs are:
Transmit Power (ERP)
802.11b: 200mW (23dBm)
802.11g: 100mW (20dBm)
Receive Sensitivity
802.11b: -91dBm (typical) at 11Mbps
-91dBm (typical) at 6Mbps
802.11g: -76dBm (typical) at 54Mbps
-96dBm (typical) at 1Mbps
Antenna
5dB External Omnidirectional
Wibberduck Antenna
The Wave antenna is better, although both can take external antennas, and Wave's size and clip-on make it more convenient.
Old 03-17-2008, 08:53 PM   #67
I've briefly messed with the WiFi SiStr program and find it to fall between netstumbler and zero configuration for usefulness. It puts a little, moveable alway-on-top (optional) window on your screen that numerically and graphically shows signal strength of the site to which you are connected. Updates quickly, less than a second in middle mode.
However, it doesn't seem to show anything UNTIL connected (NS shows them all but never is connected). So, it's good for aiming antenna to maximize signal after connecting, but doesn't help you aim at a signal to find it. Can't gripe about free stuf, with both SiStr (SIte STRength?) and NS both are.
Stealth Technology applied to Boler Air Conditioning Install Markz Modifications, Alterations and Updates 11 07-10-2010 12:12 PM
Ain't Technology Wonderful? Benita Jokes, Stories & Tall Tales 9 01-13-2007 11:38 AM
we are on the road BAMA & Pachyderm Posse General Chat 7 06-15-2006 04:02 PM
On the road again.......... General Chat 0 12-31-1969 07:00 PM
