Also, the front and rear driver's side upper marker
light lenses are missing (the originals are stamped with the
U-haul name), and two of the dinette cushions are being used as the seat cushion for the front gaucho.
The original outside seam trim was white on the ones I've seen.
It kind of looks like the cupboard door might be missing behind the carpet sample -- that is a bit odd. Also, the upper bunk is carpeted wood instead of the original fabric upholstered piece. I think the "seam strip" running up the inside is not the original greyish carpet but a replacement carpet.
The
furnace is missing. And the table is not there. Also, the original curtains and curtain wires are not there. I don't see the closet latch, but that might be out of the photo.
None of these are insurmountable problems, mind you, but then why say it is in
"excellent TOTALLY original condition"? That's what made these items jump out at me - not because they are not things that could be worked on.
Raya
PS: And actually, that is a suggestion I have made for the upper bunk on the U-hauls. Upholstered, it leaves only a very narrow ~12" deep seat on the couch. This way, you could use a Thermarest pad on it for sleeping and have more room to sit during the day.
