Hunter? $950 Oregon - Fiberglass RV
Old 10-04-2012, 10:27 PM   #1
Camilla's Avatar
Trailer: 73 Playpac
Kentucky
Hunter? $950 Oregon
12' Fiberglass camp trailer
Camilla is offline   Reply With Quote
Old 10-05-2012, 04:47 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
12' Fiberglass camp trailer - $950 (Coos Bay)
Date: 2012-10-01, 12:41PM PDT
Reply to: see below
12' camp trailer, no leaks, propane stove, heater, center top pops up so you can walk around in it. Has 900 watt inverter for household appliances, also big battery. Clean clear title and current registration. Call 54129four6911.
Old 10-05-2012, 07:44 AM   #3
Note to Kathy in Coos Bay... Buy It, and have a set!!!!!
Old 10-06-2012, 08:57 PM   #4
MsRubyLu-Kathy's Avatar
Trailer: 1987 Bigfoot 13'
Sorry, It won't fit in my driveway. It is cute but I like mine better.
MsRubyLu-Kathy is offline   Reply With Quote
Old 10-06-2012, 10:00 PM   #5
We park our pair side by side and, as a result, we are expecting a small teardrop from them any day now...
BTW: The Hunter is the male of the pairing.
Old 10-07-2012, 08:13 AM   #6
How do you take them out? I'm still figureing out how to manage one, with two dogs
However I did email my daughter. She wants a gypsy caravan and I think this would look darling painted up like one.
Old 10-07-2012, 09:23 AM   #7
RE: Which One???
Due to it's smaller frontal area and less weight, we use the Hunter for trips longer than 300 miles as it allows about 2-3 more miles per gallon than when pulling a Lil' Bigfoot or 13' Scamp size RV.
At home the Lil' Bigfoot is our Cabana and spare guest room.
The Hunter is also shared with my son who can pull it with his small Toyota.
Old 10-07-2012, 09:32 AM   #8
RE: Which One???
Is there that much difference in weight or is it only front size? What's your tow vehicle?
Old 10-07-2012, 11:01 AM   #9
Our tow vehicles are a 2010 Honda CR-V or a 2003 GMC Sonoma.
Factory weight for the Hunter was about 850 lbs. I will get mine weighed at the Lake Casitas meet at the end of the month, but Hunters that were weighed earlier typically came in at about 400-500 lbs less than a 13' Lil Bigfoot or Scamp. The Hunter is about 24+" lower and slightly narrower than the Lil Bigfoot.
I was actually comparing the MPG difference for two 500+ mile tows with the CR-V, one with the Hunter, the other with the 13' Scamp we sold several months ago.
Old 10-07-2012, 11:42 AM   #10
I somehow had the impression that Scamps were a little heavier than the lil bigfoots. It will be interesting to see the actual weight of mine loaded. I have the 2010 Pilot EX-L so the tow is okay as soon as I can learn to balance the load. I may also need to get a custom hitch for it. The dealer gave me the best fit drop hitch they had but with the water tank full it was tail heavy and real jerky to pull every time there was a bump in the road. I think I need at least an inch lower on the hitch to make it tow level. Without the water it is much better.
Old 10-07-2012, 12:48 PM   #11
Water Tanks: FWIW: Before starting out or breaking camp I always drain the water tank to reduce weight and improve balance. I carry 2 one gallon containers of water in the TV for between stop needs. But I never used tank water for drinking or cooking anyway.
Old 10-07-2012, 01:01 PM   #12
I'm planning on not using it either, at this time I will only take trips to places with water and power hookup.
Old 10-07-2012, 01:32 PM   #13
Unfortunately that will rule out a lot of nice places to stay in the NW. A fav of mine up that way is the Grayback Forestry Service Campground, just outside of Cave Junction on the way to the Oregion Caves. One of the finest forestry service campgrounds on the planet, but no hook-ups.
Old 10-07-2012, 02:52 PM   #14
Did you change your axle on the lil bigfoot? I don't have enough ground clearance at this point to attempt a rough road. I've been following what John did with his and sometime down the road I will do the axle and get a little more height.
Hunter I $950 Don W. Referrals: Molded Fiberglass Trailers 3 11-14-2011 04:51 PM
TN Uhaul $950 Resto Job melissab Referrals: Molded Fiberglass Trailers 0 05-14-2011 02:28 PM
1972 Compact Jr13ft $950 Robin G Classified Archives 2 07-10-2009 09:31 PM
16ft Scamp $950 Robin G Classified Archives 10 04-26-2009 07:00 PM
1979 Boler 13' $950 Raya Classified Archives 0 04-15-2009 09:48 PM
