MI: Toyota Sunrader - Page 3 - Fiberglass RV
Old 08-06-2015, 04:20 PM   #29
Hi Parker
If you post your questions here:
toyota-campers@yahoogroups.com
you will get a much greater range of help and answers. Just don't let anyone try to convince you that it wasn't in the axle recall and doesn't need the 6 lug, full floating, axle upgrade to be safe to drive. It does, there were no Sunrader exceptions, except for the 1978 17'er.
As in fiberglass campers, it's all about condition, condition and condition.
Old 08-06-2015, 04:47 PM   #30
Trailer: In the Market
Indiana
Excellent and will do. Thank you, Bob
Originally Posted by Bob Miller View Post
Hi Parker
ParkerSt is offline   Reply With Quote
Old 08-10-2015, 12:49 PM   #31
Trailer: sprinter looking to tow something
I have heard on 4x4 forums the manual trans gets more out of the motors. I've also seen some dyno sheets showing worn out "116hp" 22RE's making 60hp. Make sure you test drive it in conditions reflecting your type of driving. 60 horse doesn't pull this weight safely in the L.A. traffic I would want to swim in. If you're out in thin traffic it might not be an issue..
Bob, there are folks asking for advice in this thread. And that is what I'm giving, from a guy who drove a 22RE for years. If you don't agree with me thats fine, no need for snarky comments about 16 year olds and inadequacies..
Comp is offline   Reply With Quote
Old 08-10-2015, 02:09 PM   #32
I think that Parker has left the building.
But, then again I have owned many Sunrader's with the 22 series engines and did not find them lacking for power on the SoCal freeways system, which I drive on extensively. But I am well past the needs and expertise of the youngsters.
Old 12-11-2015, 11:54 AM   #33
Trailer: sunrader
should I buy a 1977 sunrader or is the engine or electrical too old to repair
eric123 is offline   Reply With Quote
Old 12-11-2015, 12:32 PM   #34
Hmmmm...he first year for the Sunrader Mini-Motorhome was 1978. I suspect what you are looking at is a 1978 Sunrader coach on a 1977 chassis. It should look like the one on the right in the picture below. The pop-up on the left is a one-off, 1989 Sunrader Adventure
To answer your question, parts are still readily available.
Also here is a link to additional pics of a 1978 I rebuilt a few years back
1978 Sunrader by Robert Miller | Photobucket
Old 12-13-2015, 12:37 PM   #35
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
Rebuilt Sunraders
Absolutely beautiful.....
Deb
( Sunrader lover too)
Deb & Chuck is offline   Reply With Quote
Old 12-14-2015, 08:44 PM   #36
Indiana
Thank you, Bob, fo rthis and your other post.
And thank you all for the other posts. It's important to know if these or any models are still getting use and still finding parts.
Thanks again, and happy holidays to all, Parker
Old 01-14-2016, 08:08 PM   #37
Trailer: sunrader
Sunrader
for Bob Miller or others. There is a 1988 Toyota Sunrader RV 18ft Touring Model - $11000 for sale that I would like to buy. Is this too much to pay for a vehicle that had engine rebuilt at 150K miles and now has about 210K on it.
this is what the add states:
This is a rare 18 footer, perfect for outdoors day trips and camping. I redesigned the interior to sleep 4 comfortably. The restoration was completed using solid Oak hardwood for the cabinets and and Pergo flooring, the lower bed is now larger by 10 inches. The kitchen area has white quartz counter top with a new 2 burner domestic euro glass top stove. I also added a 110v AC Unit that can be used with a generator. It comes with a a new front interior, the seats have been replaced with 4Runner seats for comfort and support. New Firestone Airbag and Bilstein shocks were installed in 2015, along with Yokohama tires. It has full LED lighting and SOLAR. The ARB freezer in the picture is not included. Engine was rebuilt at 150K, vehicle has been fully serviced recently. New radiator and Fan replaced during last service. Over 15K invested with the restoration and upgrades.
Old 01-15-2016, 09:06 AM   #38
vintageracer's Avatar
Trailer: Uhaul
Toyota had HUGE problems with rear-ends in 1977-1986 Cab/Chassis trucks sold to RV motorhome industry converters due to overloading of the rear drive axle. It is and was so bad that there was a recall on Toyota motorhomes.
This problem is most prevalent with the dual rear wheel equipped Toyota motorhomes that were NOT original equipped with a factory "floating axle" dual rear wheel rear-end (1977-1987). Many of the converters of the time used adapter kits to install dual rear wheels on their conversions to increase the weight capacity of the chassis to match the weight the RV manufactures's where installing on the chassis which lead to the problems of broken axles and accidents. There are also instances of the problem of rear axles breaking also occuring in Toyota motorhomes equipped with a single rear wheels do to overloading of the coach by the owner with all their "junk" they believe that is needed for camping.
The problem was resolved to a certain degree during the 1986-1987 production years when Toyota began to offer a true dual rear wheel "floating axle" rear-end in their cab/chassis trucks sold to RV converters. Apparently problems still continued through the early 1990's as in 1993 Toyota stopped selling their cab/Chassis trucks altogether to the RV industry do to liability issues.
This issue "may" not apply to this particular Toyota motorhome as it appears to be a single rear wheel model HOWEVER you should be aware of the Toyota rear axle issues in Toyota motorhomes from this 1977-1987 vintage/era and check out any Toyota chassis RV coach rear-end carefully prior to purchase as single rear wheel Toyota motorhomes from 1977-1987 are NOT totally immune to this serious safety issue/problem.
Attached is a PDF file containing information concerning this critical issue that everyone considering a Toyota motorhome should read:
http://www.toyotamotorhomes.com/files/Axle_FAQ.pdf
vintageracer is offline   Reply With Quote
Toyota Rav4 Harvey9 Towing, Hitching, Axles and Running Gear 17 04-14-2012 09:04 PM
Toyota Tundra 5.7 vs 4.6 V8 Don W. Towing, Hitching, Axles and Running Gear 20 02-29-2012 02:26 PM
Back From Toyota melissab General Chat 3 08-05-2011 03:03 PM
Toyota Cowrolla Pete Dumbleton General Chat 2 05-18-2008 03:09 PM
New Toyota Tug? Al Stansell General Chat 11 01-17-2006 09:59 AM
