05 Pilot - electric brake controller install? - Fiberglass RV
Old 10-12-2018, 04:44 PM   #1
Trailer: Looking!
Wisconsin
I have an '05 Honda Pilot w/ factory tow package installed. I want to get a 7 pin connecter and electric brake controller. I took it to U-Haul and they added a 7 pin adapter, but say they can't do the brake controller because it involves drilling and something about a firewall. I have no idea what they're talking about, but didn't think it would be such hassle? Am I missing something? Should any mechanic be able to do this? I am totally ignorant and new to this stuff so.... ???
Thanks!
Stacy T
StacyT is offline   Reply With Quote
Old 10-12-2018, 04:59 PM   #2
Thanks!
Stacy T
Find another shop. Yes you do need to run wiring through the firewall to get to the brake controller mounted in the cab. And that is done all the time. BTW the firewall is the wall between the engine and the passenger area, designed to keep fire in the engine compartment away from the people. Some liability might attach to any alterations to the firewall and that might be their objection, but like I said.. its done all the time.
A other option is a wireless controller. It would not require wires through the firewall. A good trailer shop would have at least mentioned that:
https://www.etrailer.com/Brake-Contr...sha/90250.html
https://getautowbrake.com/
Old 10-12-2018, 05:18 PM   #3
If it has the factory tow package, there should be z connector already under the dash. No drilling needed. At least that's the way my 2008 Ridgeline with tow package came. I asked my Honda dealer to dig under the dash and identify the plug, then had a local RV place wire it and install the controller. You may need a Honda-specific plug to connect to the controller.
Dave Fish is offline   Reply With Quote
Old 10-12-2018, 05:32 PM   #4
Originally Posted by Dave Fish View Post
If it has the factory tow package, there should be z connector already under the dash. No drilling needed. ..
Could be, but I think the 2005 Pilots did not come with a wiring harness for a brake controller (even with the tow package, the meaning of that term being very inconsistent). I could be wrong however so its worth confirming that before making holes in the firewall.
Also see https://www.etrailer.com/question-4304.html
Old 10-12-2018, 11:33 PM   #5
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
just about every car I've had since the early 90s already has places to run extra wires through the firewall, typically up under the driver side dash... take up the carpets, remove the under-dash kick panel, and look where the existing harnesses go through, usually they go through a big rubber plug, and there's a couple nipples on the side of this plug in different wire sizes for aux wiring, you snip off the end of the suitable sized nipple and run your wire(s) through it.
Old 10-12-2018, 11:35 PM   #6
not if the factory hitch only has a 4-pin connector, those don't use a brake controller. I've only seen factory brake controller sockets on vehicles that came with a 7-blade RV connector...
Old 10-13-2018, 04:09 PM   #7
Trailer: Coleman Destiny Cedar
My 2012 Honda Pilot EX was plug and play.
Nealster is offline   Reply With Quote
Old 10-13-2018, 05:23 PM   #8
Yes I believe the first generation (OP's Pilot) did not have the towing wiring harness and the second generation (your Pilot) does.
Old 10-13-2018, 07:03 PM   #9
Trailer: Looking!
Wisconsin
I'll take it to an RV place and see if they will do it, and I will make sure they check before drilling through firewall I just figured U-Haul would know what they were doing!
Thanks!
Old 10-13-2018, 07:10 PM   #10
Thanks!
The pimple-faced 16-year-old, earning minimum wage, in the back?
Old 10-13-2018, 07:19 PM   #11
Trailer: Looking!
Wisconsin
LOL exactly!! I swear the kid was like 13 and turns out he was the manager!!
Old 10-13-2018, 07:32 PM   #12
Thanks!
I expect you will find a huge variation between individual U-haul places. Some are great. Some are crap, and most fall in between.
John's comment about the pre-configured firewall wiring access location is worth noting. I know my van had at least one, so it was not too hard to cut the rubber back and run a wire through the firewall. The shop should look to do this before getting the drill out. In fact a little Googling can help with that:
https://www.piloteers.org/forums/19-...er-photos.html
Old 10-14-2018, 06:37 AM   #13
A regular auto mechanic should also be able to wire a brake controller. With a 13 year old vehicle, it's good to find a trustworthy independent shop that will get to know you and your vehicle.
Personally I'd go that route over an RV shop.
Old 10-25-2018, 11:20 AM   #14
Trailer: Scamp 16' Deluxe
Hi, I had a 2006 Pilot with factory tow package, used to pull my Scamp. I believe this is in the same generation as the 2005. There isn't a wiring harness for a brake controller. The tow package only has a 4 pin adapter. I did my brake controller install myself.
The wiring harness boot under the dash doesn't have any nipples to cut off (as suggested by John in Santa Cruz). If you are only running one wire to power the controller, then you might be able to push it through the boot where the other wires run through it. I was running three power wires (brake controller, inverter, aux power for trailer) through the firewall and there wasn't enough give to push that many wires through the existing opening.
I had to cut my own hole through the boot using a box cutter. Be aware that the boot is 2 sided - you'll have to cut from the engine compartment side AND the passenger compartment side. Be careful not to cut any of the factory wires that are running through the boot.
Attach your power wire to a stiff wire with tape, push the stiff wire through the boot, then pull your power wire through. If you drill through the firewall, make sure you use a heavy rubber grommet around the wire to keep it from getting worn through by the metal firewall.
Watch this video and you will see what I'm talking about around 11:40 -
https://www.etrailer.com/tv-install-...lot-90885.aspx
Hope that helps.
Kerrie is offline   Reply With Quote
For Sale: Tekonsha Pilot brake controller BO+shipping rabbit Parts: Buy | Sell | Trade 4 07-16-2013 07:25 PM
Update Electric Brake/Controller install on Boler kevin61 Towing, Hitching, Axles and Running Gear 5 01-12-2009 09:03 PM
Prodigy Electric Brake Controller Voltage Output Gary Lynch Problem Solving | Owners Helping Owners 2 02-24-2007 05:40 PM
Electric brake controller Legacy Posts Problem Solving | Owners Helping Owners 2 03-28-2003 12:04 PM
Update Electric Brake/Controller install on Boler kevin61 Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
