13' Boler with WDH - Page 3 - Fiberglass RV
Old 12-14-2010, 01:00 PM   #29
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Smile
Originally Posted by Borden View Post
Rick G the site says Quote (1500 to 2000 lbs) but wouldn't any older trailer at 17' be over that without and lot of mods. The weight of a Trillium 4500 maybe over? Is the 4500 17' ??? If it is heaver than 2000 lbs. it would require a Class II hitch or 'light duty' version of the wd with custom Class III receiver to pull.
Did see a brand new 16' 'super ultra light' at dealer that was 1600 lbs. dry but that is unusual and its flat front made it harder to pull at hyway speeds than the 17' boler.
P.S. Body twisting of the cars seems to be the fear of WD and unibody; Our car is unibody the custom hitch is fastened at the back and 2" center tube snakes forwad along bottom to be fastened again. This design lets us use a Class 3 hitch.
I actually do not have an opinion about weight distributing hitches, I was only providing the quote from the TrilliumRV website. They would be the people to ask. As for the weight of bigger trailers, yes I am sure the 17 foot Bolers and 15 foot Trilliums approach or exceed the 2000 pound range, but they were not manufactured until around 1977, about 10 years after the original models appeared. I have not weighed our 4500 yet, but from towing it a few hundred kilometres home when we bought it I don't think it was more than a couple hundred pounds heavier than our Boler, which weighed just over 1400 pounds fully loaded with camping gear. I am anticipating the 4500 will be in the 1600 - 1700 pound range when I get to weigh it next spring.
We always used a Class 2 hitch on the old Aerostar for several trailers including stickies and the Boler, and the new(er) Chevy Uplander that we bought will have a Class 3 hitch, only so that we can add a wider range of accessories to the hitch than we could with the smaller Class 2 hitch.
Rick G
Rick G is offline   Reply With Quote
Old 12-14-2010, 08:49 PM   #30
Roger C H's Avatar
Cool Trailer weight
By all means weigh it. We weighed our 13' Trillium with some stuff in it, not everything we carry, and it was 1700#.
Here is a hint, if you do not require a certified copy of the weight, some scales will let you weigh your rig no charge. That is what happened to us. If we had requested a certified weight slip, it would have been $5.
Weigh and record the entire rig, then pull the tv off the scale and record the weight of the trailer. Then unhitch the ball of the trailer with the tongue jack on the scale and jack it up until it no longer places any weight on the tv and record that. Either weigh it empty or fully loaded. (I wish I had weighed it fully loaded. This way I am not completely sure how much we carry when loaded for the road..).
Subtract the weight of the trailer from the total and that gives you the tv weight. Subtract the weight hitched from the weight unhitched and this will give you the tongue weight.
Some people like to weigh each trailer wheel individually, which if you have the time and the scale isn't busy I guess you could do. Then you will know how to load the trailer side to side.
Old 12-15-2010, 07:50 AM   #31
Borden's Avatar
Name: Borden and Carole
With water, and good ours will be over 2500 lbs. reduced trailer weight just lets us have more items like TV coffee maker, blankets and food etc. Still might even go to 3000 lbs. and that would require 300 lbs. tongue to be stable. The design of the custom hitch removes the body twist so we can safely use the WD to meet the car requirements. To the weight of the WD hitch I am adding to my tongue total and that is why I requested 400 / 4000 lb. setup. I was unable to find out if WD unit weight counts in tongue weight placed on the car but made sense to me to include it so 300 plus 50 = 350 lbs. total tongue weight. Would rather be safe than sorry. Will have to go to scale this summer and find the true weight will post the result. We may carry more cargo weight than we know.
Thanks for the tip on scales Roger C H and did like the quote Rick G on trillums.
P.S. Yes mine is 1978 and was told they were made this size for only 2 years and also was told only about 400 made with our layout not shure on this. Our bolers original weight and spec sheet has it with shower and toilet.
boler
1977 Boler 13' in Missouri Janie F Classified Archives 7 03-12-2011 12:50 AM
SOLD: 1977 13' Boler Rarebird Classified Archives 3 09-07-2010 12:11 PM
Propane Tanks for a Boler 13' Legacy Posts Problem Solving | Owners Helping Owners 11 07-18-2003 09:13 PM
13' Boler - pump faucet Legacy Posts Problem Solving | Owners Helping Owners 4 06-18-2003 03:20 PM
13' Boler - seamtape question Legacy Posts Problem Solving | Owners Helping Owners 1 06-18-2003 03:17 PM
