13' Boler with WDH - Fiberglass RV
Old 08-27-2010, 08:45 PM   #1
Trailer: 13' Boler 1977
13' Boler with WDH
is it possible to use a WDH on a 13' boler?
i heard through another forum, which escapes me know that the original trailer frame for the boler was not built to take the stress of a WDH???
any comments/sugestions on this?, ......I am pulling it with a 2003 Jetta TDi.......
thanks
Paul
pbraunton is offline   Reply With Quote
Old 08-27-2010, 09:51 PM   #2
Trailer: 1984 Scamp 13'
Maryland
Weight distributing hitches can only be used with class III and up hitches. Unless you are having a custom hitch made for your Jetta, it won't work with the car, so it is pretty much a non-issue.
Having some experience with TDIs, I have to say that they make nice tow vehicles. Lots of torque at low RPMs, so you don't have to downshift nearly as often as a similar gasoline car. The only thing I'm not too keen on is the way the US-made hitches mount to the A4 VW chassis. The Euro hitches mount where the bumper goes... much more solid. I put a Curt hitch on my '03 Golf TDI because I wanted the receiver style hitch and not the gooseneck Euro hitch that makes it difficult to mount a bike rack or cargo rack.
Anyway, I'm sure you'll do fine with the TDI. You might want to install AirLift bags in the rear springs... they really help to keep the car level with something hitched up, but don't give you a rough ride when you aren't towing, like stiffer springs would. I used them in my Golf and also use them in my Scion xD.
thanks
Paul
Old 08-28-2010, 04:00 AM   #3
Barrie Bochoff's Avatar
Trailer: 13 ft Trillium (sold 1/1/12)
New Brunswick
I pull my 13' Trillium with my Jetta (2.0L gas) and find it a great tow car, especially since I installed brakes on the trailer. I had never heard about the 'Airlift' spring bags. I checked their web site and they don't have any for the Jetta (just for vans). Have you used these on a Jetta and have you used the van set?
Barrie
Barrie Bochoff is offline   Reply With Quote
Old 08-28-2010, 05:41 AM   #4
hey thanks for the replies, ..........
i am not too worried about the pulling abilities of the jetta, I recently recovered my roof and hauled about 3000 Lbs or 1X4 strapping about a 45 min drive home, and could only do about 80 on the highway cause it would start to sway, (it was really back end heavy)
but i was more concerned about stopping, and since WDH would add more weight to the front of the car I was looking into them
i think i might just find an antir sway bar to keep my mind at ease, and just keep it slow on the way home tomorrow night, with no brakes, no swaybar, and ne experience with this trailer ................
on a side note, this is a great site, i am on the tdiclub.com forums alot, and this ones ranks up there with it, ........very informative and well laid out!!!!!!!
Old 08-28-2010, 08:16 AM   #5
Maryland
Just wanted to throw this out there... I'm not the whining nanny type, but 80+ MPH with a trailer is usually not a great idea. The faster you go, the quicker sway will arise. There are a number of things that contribute to sway, but the top two are tongue/trailer weight ratio and speed.
I don't have a problem with people driving fast when it is reasonably safe... but it is never a good idea with a trailer in tow. This is one of the reasons that car companies lower their tow ratings or eliminate them completely for the US market. There's just something about us that makes it hard to slow down. Many countries impose a separate speed limit on anyone hauling a trailer... many states in the US do this, too, but it is rarely enforced here.
As for the stopping power, the Jetta has better brakes than my Scion... but if you want more braking power, get a trailer with electric brakes (they can be added to most trailers for a couple hundred bucks).
Old 08-28-2010, 09:21 AM   #6
IllAnnoy
i think i might just find an antir sway bar to keep my mind at ease, and just keep it slow on the way home tomorrow night, with no brakes, no swaybar, and ne experience with this trailer ................couldn't resist![lol]
I assume you meant the roof of your house...And that the 3000lb was on a trailer?
Old 08-28-2010, 10:37 AM   #7
80 km's per hour so about 45 mph
Old 08-28-2010, 11:32 AM   #8
IllAnnoy
notice his location .... I'm thinking 80 "KPH".
Old 08-29-2010, 11:07 PM   #9
Maryland
Oops... That makes a big difference, doesn't it? Sorry for pestering you... I know there are a lot of people driving too fast with trailers out there, though. Every person who gets into trouble when towing with a car is just taking it one step closer to enacting more legislation preventing those of us whom tow safely from being able to do it at all.
Again, sorry for the finger-wagging.
Old 08-31-2010, 09:06 PM   #10
First one has to discover what it is that a WHD hitch does? Answer it stiffens the connection between the trailer and the tow vehicle. Without the WHD there's certain amount of weight on each axle. Add the WHD and load the torsion bar(s) to stiffen the connection and remove weight from the rear wheels of the tow vehicle. That weight removed is now applied the the front wheels of the tow vehicle and the trailer axle. Lots of excess stress on the trailer frame and suspension. Which is ok if the trailer is built for those stresses. Your Boler is NOT designed for those stresses. Results would be broken frame, destroyed axle, blown tires. In my opinion it's not a good idea.
Old 08-31-2010, 09:22 PM   #11
so i got the trailer home the other day, no issues at all, it tows like it is not even there, .......only had do down shift once while going up a hill, other than that it cruised in 5th gear most of the time, TV is an 03 jetta TDi
as for the WDH i think i am not going to need one, ....haven't weight the tongue, but the car hardly sat down when i hooked it up maybe a few inches but that's it, I plan on weighing the whole thing once i get it fixed up (door, trickle charger for battery, re-wire the interior lights and running lights) and put all the camping stuff into it
i am currently redoing the door, it was not sagging, but bowing out at the top and bottom, going to go this route for the fix, ....... http://www.fiberglassrv.com/files/BolerDoorFix.pdf
just got everything apart this evening, going to cut it into half on thursday (gotta work a 24 hour shift on wednesday), I am taking pics along the way, and will post them when i am done, ....and anything i found out of context from the above link!!!!
happy trails
Old 09-01-2010, 05:58 PM   #12
Maryland
Like I said... TDIs make great tow vehicles. VW Golf TDI was just rated number 1 tow vehicle for caravans under 3,200 pounds in the UK.
Good luck with your Boler... I look forward to seeing pictures!
Old 09-02-2010, 08:09 AM   #13
so you saying the Golf is tow rated for 3200 Lbs??, I am assuming that is with a Euro hitch that replaces the rear bumper?, or is it with a hidden hitch or similar style???
my owners manual only say 1000Lbs, ....so i am pushing that limit already!!!!
Old 09-02-2010, 08:42 AM   #14
Maryland
Yes, that rating assumes that your hitch is rated at least as high. All of the Us-made hitches I know of are rated to 2,000 pounds. The Westfalia and Bosal hitches are the heavy-duet European ones.
However, the rating I mentioned is for the new Golf. The manufacturer's rating for yours is somewhere around 3,000 pounds, but I can't remember off the top of my head. Again, only with the proper hitch setup.
boler
1977 Boler 13' in Missouri Janie F Classified Archives 7 03-12-2011 12:50 AM
SOLD: 1977 13' Boler Rarebird Classified Archives 3 09-07-2010 12:11 PM
Propane Tanks for a Boler 13' Legacy Posts Problem Solving | Owners Helping Owners 11 07-18-2003 09:13 PM
13' Boler - pump faucet Legacy Posts Problem Solving | Owners Helping Owners 4 06-18-2003 03:20 PM
13' Boler - seamtape question Legacy Posts Problem Solving | Owners Helping Owners 1 06-18-2003 03:17 PM
