13' scamp trailer total weight - Fiberglass RV
Old 05-20-2013, 09:13 PM   #1
Trailer: Currently shopping
I am looking to purchase a 2004 13' Scamp with deluxe wood interior, air conditioning and awning. Seller thinks the total weight is about 1800 pounds. I would be pulling this trailer with a 2005 Honda Element and the "owners manual" says not to tow anything over 1500 pounds. Does anyone know what the weight of the trailer is with the deluxe wood interior? Also, does anyone out there have a Honda Element that has towed a 13' Scamp with the deluxe wood package?l
Susan in AZ is offline   Reply With Quote
Old 05-20-2013, 09:18 PM   #2
total weight 13' Scamp Trailer
Old 05-20-2013, 09:33 PM   #3
Trailer: 2010 Escape 17B
You would certainly appear to be over your recommended towing capacity. Here is another similar thread and the Scamp deluxe is mentioned.
Scamp 13 lowest real weight?
kootenaigirl is offline   Reply With Quote
Old 05-20-2013, 10:06 PM   #4
Robin G's Avatar
Trailer: 2007 Casita
Total Weight? That is only something you can find out when you weigh the trailer, as well as weigh the trailer with your camping gear loaded.
The owner/seller could only know the true weight if they had ever weighted it.
I really suggest you read this post, it might help you get a guesstamate of what the trailer might weigh. But again the only way to know exactly what it weights is to weigh it. So worth the $10/20 bucks to find out.
Trailer Weights in the Real World
Old 05-21-2013, 04:00 AM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Hide the little kid in Colorado.
Old 05-21-2013, 04:50 AM   #6
Hi Susan, even if the seller is correct at 1,800 lbs, you're already over weight for your tow. But, I think you know that....
Old 05-21-2013, 06:35 AM   #7
deryk's Avatar
New Jersey
Well Susan you have a few choices. Buy a trailer you can't tow because its over your vehicles tow capacity (an that is unloaded, no water, food, etc) Attempt to tow something that is beyond your vehicles ability and either put it in an early grave or lots of repair bills, Look for a smaller trailer, or look into a larger tow vehicle.
1500lbs is what my PT Cruiser had for a tow capacity and I built a small teardrop trailer sized trailer out of cedar that weighed in at 650lbs empty. I kept it light sold them both got my Rav4. You dont really want to be towing at your vehicles max capacity regularly. I have a 3500lb tow capacity, My ParkLiner is around 25-2600lbs loaded to go away.
deryk
Old 05-21-2013, 09:25 AM   #8
Susan the best thread to look at on this forum that others have pointed you to is the Trailer Weights in the Real World for a better idea as to what the trailer may weigh once you pack your own belongings in it. Most of the trailers on the list were weighed on arrival at a Fiberglass trailer meet in Oregon which had full hook ups - so the odds are high that most of them did not have water in any of the tanks. A good rule of thumb is to add about 500/600lbs to a trailers dry towing weight to come up with a more realistic towing weight once you get your own stuff loaded up. FYI many of the 13' trailers also dont have trailer brakes which is a fairly common requirement by vehicle manufacturers if towing trailers over 1000lbs or so.
Old 05-21-2013, 09:32 AM   #9
Thomas G.'s Avatar
You should buy a Ford F450 pickup to be on the safe side, but drive 45 mph or less.
Old 05-21-2013, 09:36 AM   #10
Trailer: Casita 17 ft DLX SD
My 16 ft Scamp standard SD with bath & options weighed 1960 lbs when it left the factory (weight from Scamp scale ) Loaded weight when ready to camp is between 2500 Lbs & 2600 Lbs (food, beverages ,water ,clothes ,propane ,bedding , cooking utensils ,empty grey & black water tanks, Etc.) It doesn't take long for the weight to climb. I would ask Floyd , he has a 13 ft deluxe and may know the loaded weight
Old 05-21-2013, 09:46 AM   #11
Diesel / towing package
I am assuming the F450 is equipped with a diesel engine and heavy duty towing package in order to be on the safe side ?
Old 05-21-2013, 10:16 AM   #12
Thomas G.'s Avatar
Of course! With dual rear wheels and the ambulance package cooling and dual alternator option. But I would only drive it on a flat, straight highway, preceded by a signal truck with flashing amber lights to alert motorists endangered nearby.
Old 05-21-2013, 04:21 PM   #13
South Dakota
I have a 2010 Scamp 13 Deluxe with birch interior with all the options that Scamp has available such as bathroom, 2 LP tanks, larger battery, awning, rear hitch, extra cabinets, etc. plus I have installed a microwave, rear carrier with Honda 2000 generator, solar panels, under cabinet tv, etc.
My total weight with water tank full and LP full is 2,300 lbs.
I pull with an Acura MDX (similar to Honda Pilot) which has a tow rating of 2500 lbs. It pulls very good with this setup. I also carry a full 5 gal water jug in the front bathroom to offset the weight of gen. in back.
Dale
daletomlinson is offline   Reply With Quote
scamp, weight
Total height of Boler trailer? DannyH Care and Feeding of Molded Fiberglass Trailers 25 06-23-2016 12:21 PM
help - I am interested in buying a small, light weight trailer- total weight 2000 pdd pwedd Hi, I am.... 19 07-23-2011 12:50 AM
Total Axle Exchange on 1980's Scamp trailer Peter Hansen Towing, Hitching, Axles and Running Gear 10 05-04-2011 04:30 PM
Trailer weight Dale N General Chat 1 04-08-2008 10:26 PM
trailer weight Gerry O Classified Archives 0 12-31-1969 07:00 PM
