13ft don't require brakes? - Page 3 - Fiberglass RV
Closed Thread
Old 03-27-2012, 01:50 PM   #29
IllAnnoy
Originally Posted by Darwin Maring View Post
When you're on snow / ice and you panic stop B sure to look left and right and wave at your brakeless trailer as it is passing you.
HEY! Carol H said there was no controversy!
floyd is offline
Old 03-27-2012, 02:18 PM   #30
Dang Floyd your right! Perhaps I should rephrase that to say there is no controversy as to whether or not the trailer should have brakes for those who choose to follow the laws of the state &/or provinces they tow in and follow their tow vehicle manufactures requirements/capacity or for those who wish to respect the safety of those whom they share the road.
Carol H is offline
Old 03-27-2012, 03:07 PM   #31
And the laws of physics.....
BCDave is offline
Old 03-27-2012, 04:47 PM   #32
james kent's Avatar
Trailer: Boler 1984
We have towed our Boler without brakes several times from Ontario, across the Prairies and through the BC mountains and back, with several different vehicles since 1994 without any problems. Although if I were to use smaller tugs [Than the v6,s or v8,s] then I might think seriously about adding brakes.
james kent is offline
Old 03-27-2012, 05:11 PM   #33
IllAnnoy
Most states don't require brakes on trailers under 1500#. I'm not against brakes. I am against fear mongering,and hyperbole.
I have brakes on my trailer eventhough they are only required in a few states under 3000LB.
There is no need to claim the force of law, where none exists, to support prudent advice.
floyd is offline
Old 03-27-2012, 05:41 PM   #34
Prudent advice to me is "It's better to be safe than sorry."
This also applies to Gas, Monoxide, Fire and Smoke detectors and heaters equipped with low oxygen shut down device . It may not be required however it is better safe than to be sorry.
Darwin Maring is offline
Old 03-27-2012, 06:07 PM   #35
IllAnnoy
Pretty much what I said, you choose what makes you comfy and calms your fears. Don't forget deadbolts, firearms and vicious dogs!
Caution... Prudence is precluded by the imposition of jurisprudence,You can hardly advocate both for the same act.
floyd is offline
Old 03-27-2012, 06:42 PM   #36
Kenny Strong's Avatar
Trailer: Bigfoot 13'
Utah
Hi all
I have a 13' Bigfoot, came with brakes. Driving up through Canada and Alaska, I disconnected the brakes when I was having a bent axle repair. It was a noticeable difference with and without brakes. I choose brakes!
Later Kenny
Kenny Strong is offline
Old 03-27-2012, 06:47 PM   #37
As you will note Floyd I did say the law in the state they live or tow I didn't say they were required in all states ;-)
The problem Floyd is that if you take a look at the Real World Weights and tell me how many 13' Scamps do you see weighing in at under 1500lbs??? Perhaps my eye sight is getting worse with my age. ;-))
Yup there may only be only about 7 states that would require brakes by law on a 13' Scamp based on real world weights & 9 states that would require brakes on a 13' Casita as all of them on the list weighed in at over 2000lbs. But even if you dont live in those states you should be aware of the law should you drive through one of them.
Some of the states & provinces with brake requirements under the 3000lb are:
California - 1500lbs
Idaho - 1500lbs
Nevada - 1500lbs
Tennessee- 1500lbs
North Carolina - 1000lbs
New York - 1000lbs
Ohio - 2000lbs
Utah - 2000lbs
Georgia - 1500lbs
Manitoba - 2000lbs
Yukon - 2000lbs
Alberta - 2000lbs or if trailer exceeds 50% of the vehicles weight.
Quebec - 3000lbs or if the trailer exceeds 50% of the vehicles weight.
Carol H is offline
Old 03-27-2012, 08:42 PM   #38
IllAnnoy
Idaho - 1500lbs
Nevada - 1500lbs
Tennessee- 1500lbs
New York - 1000lbs
Ohio - 2000lbs
Utah - 2000lbs
Georgia - 1500lbs
Manitoba - 2000lbs
Yukon - 2000lbs
As you will note I did say that the use of brakes was a matter of prudence, which I supported.
So let's drop the ruse, it's jurisprudence which you, and some others, advocate... not prudence.
As for me, I will opt for prudence and leave my brakes hooked-up without regard to which state I am in.
Some folks simply believe that a person should be allowed to do anything he pleases... as long as it's mandatory.
floyd is offline
Old 03-27-2012, 09:30 PM   #39
Trailer: Fiber Stream
Originally Posted by Thomas G. View Post
I think the OP has left in favor of a conversion van.
I finally got to read this thread. Sorry I'm late to the party.
I think this discussion has run its course.
Frederick L. Simson is offline
Closed Thread
brakes
So you think you don't need trailer brakes? Donna D. Towing, Hitching, Axles and Running Gear 49 12-19-2011 09:42 AM
I don't know what to do next? Dawn S Problem Solving | Owners Helping Owners 26 09-08-2009 02:35 PM
OK, I am getting old? And I don't know it? Gina D. General Chat 49 06-04-2006 01:28 AM
