16' Scamp axle - Fiberglass RV
Old 04-02-2014, 06:13 AM   #1
Trailer: Scamp 16'
New Hampshire
16' Scamp axle
im getting my scamp ready, and its a early 16' model with a 2000lb axle in it, I would like a 3500lb axle maybe dexter axle, does anybody know a part number for the dexter axle?
Gilles1 is offline   Reply With Quote
Old 04-02-2014, 07:23 AM   #2
Scott
The Dexter PN is #10 (Torflex). The P/N just specifies the weight range of the axle. They are custom built to your specifications.
Eddie
10TF35-545E-EZ, #10, 5x4.5 lug. electric brake, ez lube. You have to provide measurements for perch spacing & height, Hub face to face spacing, Swing arm angle and axle capacity. And if you want bolt on brackets. Most vendors have order work sheets to fill out when ordering.
axle, scamp
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
» Trailer Showcase
2011
brian m.
Bubbles
Dawnette
