17Ft Bigfoot Axle - bent? - Fiberglass RV
Old 08-26-2009, 05:22 PM   #1
Trailer: '78 Trillium 4500
Hello -
Looking at a 1983 17.5' Bigfoot today and noticed the axle had an 'arch' or bend to it like so: /\
Coming from a 13ft Trillium, I wasn't sure if this was due to an accident or if it was part of the design for larger trailers
I asked the owner (who up to now seemed honest & straight up) if it was bent, and he replied that it was designed that way to be able to adjust the tow in and/or camber of the wheels. Now I'm not so sure as all replacement axles I've seen are straight and he was honest in all other answers/aspects.
Should the axle on these be straight across?
Thanks,
Dave
Dave_L is offline   Reply With Quote
Old 08-26-2009, 09:31 PM   #2
DayTripper's Avatar
Trailer: 1995 Casita FD , 2003 Chariot 13 (Stealth Egg) , 1987 Casita LD
<span style="font-size:10pt;line-height:100%">Here is more of a non-answer ............
1) 30 years ago we aligned the front ends of Ford Trucks by bending the axel to get it within specs.
2) Last week I found an alignment shop in town that still had the old equipment and I took my 87 Casita in and had them bend the axel to align everything perfectly. I now have a visible arch to the center of my axel that looks exactly like I hit something. Prior to the alignment it was straight.
(and she now tows like a dream)
The PO may have had it aligned .................. Just a thought ............</span>...
DayTripper is offline   Reply With Quote
Old 08-27-2009, 01:47 AM   #3
Trailer: 84 16 ft Scamp
When I acquired my Scamp about ten years ago, the tire wear indicated an alignment error. I found a shop in Tacoma, WA that corrected the alignment by bending the axle.
The process is pretty crude -- just a heavy duty hydraulic jack against a chain attached at the ends of the axle. Jack, then check. Jack some more, then check. Repeat until satisfied.
All in all it took 15 - 20 minutes, as I remember, with the trailer on a lift.
After that the tire wear evened out and it tracks great.
Old 08-27-2009, 07:10 AM   #4
BobB's Avatar
Hi Dave,
Quite a few Bigfoot trailers have Standens axles; ours does. A slight arc upward, highest in the middle is probably normal. Some axles seem to be built that way. The 2005-8 Bigfoot 17.5 has a drop axle, while our 2004 Bigfoot 17 has a straight axle. I just don't know about the 1983. Some trailers end up with bent axles from hitting curbs and other obstructions in campgrounds and on roads. That might cause uneven tire wear which can be corrected by having the axle re-aligned, straightened or replaced. If you don't have uneven tire wear, you are probably OK!
Old 08-27-2009, 07:37 AM   #5
Joe Z's Avatar
New River AZ
My Torflex axle was installed new in 2004 and it has the upward bend
Joe
A little hard to see the bend in the picture but it is there!
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 08-27-2009, 10:24 AM   #6
Raya's Avatar
I looked at a Trillium 4500 that had the "arched" axle, so I did a bit of Internet searching. What I gathered was that it is normal for a torsion axle to have such an arch.
I don't know if that means every one should have an arch, but rather that the arch is not necessarily abnormal.
Raya
Old 08-30-2009, 02:10 AM   #7
Thumbs up
Raya
Having gotten under it finally, its a 'camber bend'.
However, the trailer sits too low for our intended use so I need to get about another 4" of clearance. Its a leaf sprung drop axle at the moment, so options are: move springs to overslung, straight axle with leaf springs, or move to a Torflex?
Any reason NOT to go up to the Torflex and lose the leaf setup?
Dave
Old 08-30-2009, 07:36 AM   #8
Trailer: 94 Casita 16 ft
Dave
I've always got the same answer to give for this type of question: Look under the back end of any pick-up truck and you'll find leaf springs. Simple. Durable. Repairable. If you need ride quality on a trailer, then shocks can easily be added afterwards.
I'd say go with the straight axle, then add shocks. Even if you had a shop do all the work, it'd be much cheaper than a torsion axle swap.
Paul from NWOnt is offline   Reply With Quote
Old 08-30-2009, 08:55 PM   #9
Yep, looks like I'll go the way of the straight axle and throw shocks on if need be for damping.
Now, to price out 15" rims & tires
Old 09-13-2009, 04:07 PM   #10
Tim D.'s Avatar
Trailer: 1991 17 ft Bigfoot
anystate
Just another two bits on the axle bow. We have a 1986 Bigfoot 17'. When we bought it our tires leaned inward from the top and had their insides chafed. The axle appeared straight across. After an axle alignment the tires stood straight up and down and the axle had a bow in it the way you described. Subsequenly the problem returned, so we replaced the axle. The new axle also has an upward bow in it.
1991 Bigfoot 17 Rear Bath
2006 Dodge Sprinter
Tim D. is offline   Reply With Quote
Old 09-14-2009, 12:04 AM   #11
Trailer: 2000 Bigfoot 17 ft (15B17CB)
Yes, tires leaning inwards on Bigfoot 17's is pretty common with age. This is because most are pushing the 3500lb axle rating and with time will bend the axle. As several have stated, the axle should have a upwards bend in the center, if it is straight, it is approaching it's design load or already bent.
I think people should really weigh their trailers fully loaded and with a full tank of water. I think some would be in for a shock.
Steve.
Steve C. is offline   Reply With Quote
axle, bigfoot
1986 17ft Bigfoot Gina D. Referrals: Molded Fiberglass Trailers 0 06-13-2010 03:27 PM
Bigfoot 17ft $7000 Robin G Classified Archives 0 04-19-2009 08:55 PM
SOLD - Bigfoot 1990 17ft David H. Holsinger Classified Archives 8 04-10-2007 09:43 AM
Bent Axle? Legacy Posts Towing, Hitching, Axles and Running Gear 3 08-04-2003 12:26 PM
bent axle? Legacy Posts Towing, Hitching, Axles and Running Gear 7 07-21-2003 11:18 PM
