21" to top of ball ? - Fiberglass RV
Old 06-16-2012, 07:41 PM   #1
Trailer: Scamp 16'
Indiana
I towed my new to me Scamp 16 home yesterday. I noticed that the front was tipped lower than the rear of the trailer. It didn't look very streamlined.
When I got home I checked the on line manual from Scamp and saw that the measurement from the ground to the top of the ball should be 21"
To get that measurement I'll have to turn the draw bar 180° and swap the ball around. Any problem with using the draw bar like this?
FlyboyTJ is offline   Reply With Quote
Old 06-16-2012, 08:06 PM   #2
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
No go for it.
Old 06-17-2012, 03:45 AM   #3
Raz
Raz's Avatar
You may find turning the ball around a challenge as they typically are torqued to 200-250 foot-pounds. Raz
Old 06-17-2012, 07:47 AM   #4
cpaharley2008's Avatar
the stingers can be used in either direction, but as Raz indicated maybe hard to remove the ball.
Old 06-17-2012, 08:09 AM   #5
Thomas G.'s Avatar
Just slip a piece of pipe over a large crescent wrench. In extreme case, hit it with penetrating oil and maybe a little heat from a propane torch.
Old 06-17-2012, 08:11 AM   #6
and flip it 90 degrees in the hitch for leverage
Old 06-17-2012, 08:21 AM   #7
Thomas G.'s Avatar
Good tip. Gravity is your friend.
Old 06-17-2012, 08:50 AM   #8
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
When I changed TV' from the Trailblazer to the Explorer, I had to flip mine 180 also.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 06-17-2012, 10:10 AM   #9
Trailer: Scamp 16'
Indiana
Thanks for the replys folks. My TV is a Ford Explorer Sport Trac with a factory hitch. It must be lower than other types of trucks. I think the tip about turning the draw bar 90° for better leverage is great and will make loosening the ball much easier. Thanks.
Old 06-17-2012, 10:34 AM   #10
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
with my friends Scamp, reversing the receiver,made the rear door on his Honda vulnerable to impact with the trailer coupler , so be careful when backing up to the Scamp, leave the front of the trailer lower until in position.
Kenny Strong is offline   Reply With Quote
Old 06-17-2012, 11:40 AM   #11
A fellow forum member Brian B-P informed me that flipping the stinger may not always be advisable UNLESS the manufacturer has noted weights on each side. I never paid much attention to the fine print but he advises to read what is imprinted on the hitch stinger. Some may not be eligible for flipping so PLEASE check with the manufacturer to determine the limits to be placed on the unit.
Old 06-17-2012, 12:06 PM   #12
Trailer: 2010 Scamp 16
Especially after several decades of morning donut with my coffee....
Like the tips will file away in mental attic.
Old 06-17-2012, 06:16 PM   #13
Raz
Raz's Avatar
Good ideas for removal. How about tightening to the right torque? My wrench doesn't go that high.
Old 06-17-2012, 06:43 PM   #14
Thomas G.'s Avatar
I've faced that problem and I just stood on the wrench at the appropriate distance. For example 200 foot pounds = a 200# man standing at a point 1 foot from the bolt. Or 100# man standing at a point two feet from the bolt. It is linear.
Old 06-17-2012, 06:52 PM   #15
Raz
Raz's Avatar
Do you think the RV places actually use a torque wrench or the technique you've suggested. Perhaps a breaker bar and a whippin' big pipe?
Ball Height LizP Towing, Hitching, Axles and Running Gear 6 04-26-2009 07:20 PM
Top Bunk Safety Net / Feature for 13" Camper Carl G Modifications, Alterations and Updates 7 03-29-2009 10:09 PM
To grease the ball, or not?? John W Simmons Problem Solving | Owners Helping Owners 27 08-16-2006 11:08 PM
