5th wheel hitch & Tacoma composite beds - Page 2 - Fiberglass RV
Old 01-17-2013, 06:14 AM   #21
Alf S.'s Avatar
Hi: P. Raz... For every angle... there's usually a hitch!!!
Old 01-17-2013, 10:41 AM   #22
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
The Subaru Forester has two tubes that run underneath from about the rear seat to the back of the vehicle . On a truck, they would be the frame. When the bumper is removed, the open ends are exposed (first picture below). After the mufflers are removed, the hitch is installed by fishing bolts through the end of each tube (second picture below) and out the bottom. The problem you are having is because the pictures I have shown are 1) after and then before installation and 2) opposite sides. Standing on your head might help as might identifying the heat shield and the rubber muffler hanger in each original photo. Four bolts ( two per side) through the sheet metal tubes are what fasten the hitch to the vehicle. Fortune favors the bold . Raz
Did you run outside and take that all apart just for me, you big ol' hunka hunka sweetie pie, you? ...
I think I'm starting to get the picture...do you mean that the hitch has a couple of arms that slide into the channels for their full length, and it's those that the bolts go to? I'd love to see pics of the before-installed hitch itself, hint, hint...
I can wait if you haven't gotten to the "put it back together" stage yet!
Thanks!
Francesca
Old 01-17-2013, 11:03 AM   #23
Raz
Raz's Avatar
Thanks!
Francesca
Pictures are from last June. The hitch is the black thing with the two bolts in it.
Old 01-17-2013, 11:23 AM   #24
Yeah- I was kidding!
This is the only pic showing a "black thing with two bolts in it"- do those bolts go through to whatever it is that "slides into the tubes" that you mentioned earlier?
Thanks!
Francesca
Old 01-17-2013, 03:03 PM   #25
Raz
Raz's Avatar
Thanks!
Francesca
Nope. You feed a piece of wire with a coil at the end through holes in the bottom of the tube and out the back, thread the bolts into the coil one at a time and pull them into the tube and they hang down. When all 4 bolts are in place you lift the hitch up and thread nuts on the bolts. Tighten, torque and you're done. Removing the rear bumper and mufflers was the hard part. If you are really interested, etrailer has a video although they do it the hard way. Raz
Old 01-17-2013, 03:13 PM   #26
This is the way the factory hitch is meant to be installed???? Yikes!
I'd love to see the E-trailer vid- got a link to the one you mean?
Thanks!
Francesca
Old 01-17-2013, 05:02 PM   #27
Raz
Raz's Avatar
Thanks!
Francesca
The factory hitch bolts to the 3 studs surrounding the tube with a stiffener that feeds into the tube. The after market hitches all bolt to the bottom of the tube. While I removed the bumper, the etrailer folks place the bolts in the tube a little differently..... Don't forget to make pop corn.
Trailer Hitch for 2012 Subaru Forester - Curt 13147
Old 01-17-2013, 05:25 PM   #28
Thanks, Raz!
VERY interesting...and I'll bet it would be even more interesting if I'd been able to get the sound to work. (Hubby's been fiddling with the computer speakers again )
But I could pretty much see how the Curt goes on. I think both your and their methods of getting the bolts on are pretty clever!
You mention that the OEM hitch comes with a "stiffener"- what does that look/install like? (I'd look it up myself except I'm not a member at the Subaru site.)
Are you at all concerned about not having that stiffener? I know your Trillium's less than 2,000 and doesn't need a w/d, but still...those four bolts/washers do look as if there'd be considerable concentration of the load at those points.
Thanks again...
Francesca
Old 01-25-2013, 10:55 PM   #29
Trailer: 2001 19' Scamp fifth wheel
I have a B&W turnover hitch on my 05 Tundra and I wouldn't trade it for any hitch that takes up bed space. No drilling holes in the frame it uses the existing frame holes the only down side is the 4" hole I drilled in the bed! The ball flips over and is flush with the bed when not in use.
I don't see Taco's listed on the web page but you could contact them and ask if they have a model that would work.
Philmag1 is offline   Reply With Quote
Old 01-26-2013, 06:39 AM   #30
Raz
Raz's Avatar
That's very clever. Obviously it allows a Scamp to clear the sides? Did it take anything special to do that? This site has good pictures. Raz
B&W Turnover Ball Gooseneck Hitch
Old 01-27-2013, 06:23 PM   #31
The previous owner raised the Scamp 3" with square tube steel. I got the idea from him he had a Dodge pickup with the turnover hitch. The only downside is I need to figure out how to get stairs mounted to reach the door!
Old 01-27-2013, 08:31 PM   #32
Hi all,
Sorry now I understand, here are a couple of photos of my hitch. And the 3" axle raised. Again I purchased the Scamp with this set up so I assumed it was a standard Scamp hitch. I looked at the Scamp bed hitch but I did not like giving up the bed of the truck so I opted for the B&W turnover. It has a much higher load rating and it is bolted between the truck frame so its bullet proof.
Old 01-27-2013, 09:58 PM   #33
This would be my next addition to the hitch. I bet this would really make the ride nicer. My Tundra has a soft tail and I bounce pretty good on the bad California roads.
Shocker Hitch - Air Suspension Trailer Hitches
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
5th wheel to bumper hitch jackstrr Modifications, Alterations and Updates 7 06-11-2011 08:50 AM
5th wheel hitch set up garycoughlin Problem Solving | Owners Helping Owners 5 05-25-2011 05:39 AM
Can a 2007 Toyota Tacoma tow a Scamp 5th wheel trailer? Gary Foster Modifications, Alterations and Updates 4 03-28-2007 02:21 PM
