5th wheel scamp to a bumper hitch - Page 2 - Fiberglass RV
Old 11-17-2014, 04:56 PM   #15
Trailer: 77 Scamp 13
Originally Posted by Darwin Maring View Post
Ridgelines have high sides and Fords tend to somewhat high.
If he has one like Steve pictured above then why not Jack The 5R to match the truck. Honda
From what I have heard it is not the truck is too high but the sides are, even if you lowered the truck the bed sides would be in the way. Pretty sure it can be made to work if you only travel in a straight or nearly straight line. You just strap that hitch down with some spacer blocks. Add some chains so it can't slide off the back and away she goes.
Old 11-18-2014, 06:57 AM   #16
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
The new style of Scamp 19 hitch is a Reese bracket and rails. It has several inches of height adjustment to accommodate the depth of different beds. It is at the lowest setting in my Tacoma. Its bed is only 15 inches deep.
Old 11-18-2014, 07:16 AM   #17
An additional thought: While there is a slight difference in hitches between the one you are looking at and current production, you might try asking SCAMP what solutions they have for connecting your make, year and model pick-up to a new SCAMP 19'er.
I have heard that they have a lift kit of some sort.
BTW: Post what your vehicle is, someone here may have already found a solution.
Old 11-24-2014, 06:13 AM   #18
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Several things.
1. The current axle is likely shot.
2. It likely has 13" tires.
3. A lift is available from scamp, although it requires cutting and welding, that will be necessary anyway, if your axle needs to be replaced.
I towed mine home with an adapter the PO had built. It braced back to the bumper with chains. The titan had zero issues pulling it that way.
Name:	ImageUploadedByFiberglass RV1416834488.405949.jpg
Name:	ImageUploadedByFiberglass RV1416834532.315363.jpg
I couldn't bring myself to leave it that way. It was so low, it put a small dent in the tailgate when I turned sharp while pulling it home.
I put a new axle, 3" lift, 225/75/15 tires on it, and made it a real fifth wheel.
Name:	ImageUploadedByFiberglass RV1416834719.386615.jpg
Name:	ImageUploadedByFiberglass RV1416834777.993261.jpg
It was well worth the effort, IMHO.
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 01:04 AM
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
5th wheel to bumper hitch jackstrr Modifications, Alterations and Updates 7 06-11-2011 08:50 AM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
5th wheel bumper pull jeff y Towing, Hitching, Axles and Running Gear 0 12-31-1969 07:00 PM
