7 pin power question - Fiberglass RV
Old 06-02-2013, 08:39 AM   #1
Trailer: bigfoot
Saskatchewan
I am new to towing, and I have a question about the power running to the 7 pin connector. It seems that the power is live to the battery and not the ignition, so if (assuming I turn off every light, etc. in the camper) I leave it plugged in will it drain the tow vehicle battery? What if the camper battery is fully charged, will it still take power from the tow vehicle battery?
Thanks!
spartacus is offline   Reply With Quote
Old 06-02-2013, 08:57 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
The trailer will drain the tow vehicle battery if not disconnected. The usual solution is to install a relay wired to the ignition so it disconnects automatically. You can also install an isolating diode, but be sure to get one with a low voltage drop or it will hamper your trailer battery charging.
Old 06-02-2013, 09:08 AM   #3
IllAnnoy
Thanks!
If what you say is correct, then a draw from the trailer will drain the TV battery.
Many systems use a battery isolator which will prevent this when the key is off.
I use an inline breaker and a manual 30A switch with an LED indicator light.
As you say, if the battery on the trailer is fully charged and has no load applied then it will not drain itself or the TV battery.
Old 06-02-2013, 09:19 AM   #4
Thanks!
There's not a yes or no answer, it all depends.
When connected in the manner you describe any power consumption devices in the trailer will draw from both batteries, any devices in the tow will draw from both batteries. With nothing on in the trailer except the propane detector it will take several days to run both batteries down. A stop for lunch or even over night is NOT going to have much effect.
FYI, my factory tow package connects the battery in the tow directly to the battery in the trailer when the trailer is plugged into the tow. My standard procedure is to disconnect the trailer when camping, or a quick overnight sleep. I leave it connected for all rest stops including meal brakes.
Hope this helps a bit.
Byron Kinnaman is online now   Reply With Quote
Old 06-02-2013, 10:03 AM   #5
A solenoid type battery isolator is readily available at most RV stores, as well as on line, for less than $20 and is easy to install. It assures that the trailer is disconnected from the TV battery unless the ignition switch is turned on
These are pretty much standard equipment on motorhomes to protect the engine battery from being run down by the coach when parked.
Old 06-02-2013, 10:07 AM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I added an isolation relay when I wired the RAV4 charge line. Luckily, there was a 12V receptacle in the rear side panel of the RAV4 that I used to feed the sense coil of the relay.
If you have a 12V heater in your refrigerator & use it while driving, the relay is important - if you forget to unplug the trailer during a long lunch you may find everything dead...
A Question About Shore Power Red-Dwarf Problem Solving | Owners Helping Owners 10 03-21-2012 04:20 PM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
7-pin wiring question Bonnie Problem Solving | Owners Helping Owners 3 07-28-2007 11:51 AM
Battery power question Sharon Herman Care and Feeding of Molded Fiberglass Trailers 31 03-30-2006 09:39 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
