7 pin RV plug installation in 2013 Ford Escape with factory tow package - Page 3 - Fiberglass RV
Old 03-09-2014, 03:23 PM   #29
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Rick, my P3 Tekonsha brake controller (89762) also can mount 360 degrees.
People in the know tell me Ford did not provide 7 pin plug & play for the Escape for fear it would cut into F-150 sales. Gee.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 03-09-2014, 07:45 PM   #30
Originally Posted by Rick Mooyman View Post
I bought a quick disconnect so I can move the controller from vehicle to vehicle. Ya they are not cheap and easy to disconnect it when it is not needed too. I am not going to permanently mount mine. I am going to stand it up in the door pocket when I use the trailer and pop it into the center console when not needed. This way there are no holes in the dash and it will not get in the way of my leg room.
Rick
With it in your door pocket is it tight? if not what are you going to do if you ever have to use the lever on it to stop sway in a do or die situation?
3M makes a marine velcro that holds well. I have used to mount a controller and avoid the need for screws into the vehicles dash area.
Old 03-12-2014, 05:43 AM   #31
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Fits in the door pocket perfectly and the controls are right there for your left hard to reach if you need to.
Rick Mooyman is offline   Reply With Quote
Old 03-12-2014, 07:42 AM   #32
Ice-breaker's Avatar
Originally Posted by frank_a View Post
...Just mounted the brake controller. Had to take it out of the pickup. Was just gonna buy another one so we'd both be set, but they're 125 bucks. They can move back & forth all they want...
Frank
I use a wireless brake controller from Tekonsha (http://www.tekonsha.com/content/prod...435&part=90250) that is highly portable between vehicles and does not need to be hardwired into your tow vehicle. (The only part you move between vehicles is the controller which plugs into your vehicles 12V accessory outlet). Costs a bit more than a conventional controller, but when you factor in the savings on having to wire it in, it may be comparable.
Ice-breaker is offline   Reply With Quote
Old 03-12-2014, 08:38 AM   #33
frank_a's Avatar
Originally Posted by Ice-breaker View Post
I use a wireless brake controller from Tekonsha (Brake Controllers - Tekonsha) that is highly portable between vehicles and does not need to be hardwired into your tow vehicle. (The only part you move between vehicles is the controller which plugs into your vehicles 12V accessory outlet). Costs a bit more than a conventional controller, but when you factor in the savings on having to wire it in, it may be comparable.
That would have been great for the Escape, but my F-150 is plug & play, so all I need now is another quick disconnect mount, see most everything else is done already. But that sure is a great solution for any 2013/2014 Escape with the 3500# tow package! Saves a bunch of work and effort!
Frank
2012 ParkLiner #006
escape
Ford Escape Factory Towing Package SurfsideEd Towing, Hitching, Axles and Running Gear 38 03-26-2013 06:43 PM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
Do you have a SMALL SUV with a factory towing package? Karalyn Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
